The Cisco RV325 dual gigabit WAN VPN router is no exception. Featuring intuitive user interfaces, it will have you up and running in mere minutes. The capable router provides reliable, highly secure connectivity for you and your employees and work so well that you won't even know the router is there.
- Cisco Small Business RV325 - router - desktop
- Router - 14-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- NAT throughput: 900 Mbps , VPN throughput (IPSec): 100 Mbps , VPN throughput (SSL): 20 Mbps
- Capacity
- Virtual interfaces (VLANs): 17 , PPTP VPN tunnels: 10 , SSL VPN tunnels: 10 , VPN tunnels (site-to-site): 25 , IPSec VPN tunnels: 25 , Concurrent connections: 40000 , ACL rules: 50
- PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing, RIPng
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- DMZ port, NAT support, hardware encryption, VPN support, PAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, E-mail alert, IPv6 support, firmware upgradable, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server, reset button, bandwidth control, DHCP relay, DNS relay, DHCP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
- 24.3 cm x 17.7 cm x 4.5 cm
- Localisation
- Taiwan, Thailand, Singapore, India, Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, FCC Class B certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
- Status Indicators
- Port transmission speed, power, WAN, DMZ, link/activity, DMZ/Internet, diagnostic, USB, VPN
- LAN: 14 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Software Included
- Drivers & Utilities
- 24.3 cm
- 17.7 cm
- 4.5 cm
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.69 |
C2G USB Superbooster Extender Kit | In Stock | £35.89 |
