Cisco Small Business RV134W Router 4-port switch - GigE
Quicklinx: CZL8WS00 Mfr#: RV134W-E-K9-G5
  • IEEE 802.11n
Hurry, only 1 left in stock!
£135.78 ex VAT
£162.93 inc VAT
When you need Very High Bit Rate Digital Subscriber Line 2 business networking connectivity, the RV134W is an ideal product. This model offers a robust firewall and VPN for highly secure communications. Its Ethernet WAN port makes it a flexible solution.
Cisco Small Business RV134W - router - 802.11a/b/g/n/ac - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
SIP, ADSL2+, VDSL2
Cellular Protocol
LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Performance
NAT throughput: 750 Mbps , VPN throughput (3DES/AES/IPsec): 20 Mbps
Active VLANs: 6 , Concurrent sessions: 7500 , Number of concurrent clients: up to 100 , Maximum number of configured SSIDs: 8 , Maximum number of configured SSIDs (2.4 Ghz): 4 , Maximum number of configured SSIDs (5 Ghz): 4
Network / Transport Protocol
PPTP, NTP, ICMP/IP, PPPoE, DHCP, DNS, Bonjour, DHCPv6
Routing Protocol
RIP-1, RIP-2, IGMP, static IPv6 routing, RIPng
Remote Management Protocol
HTTP, HTTPS, SSH, CLI
NAT support, PAT support, NAPT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, ALG support, port mirroring, E-mail alert, IPv6 support, firmware upgradable, Rapid Spanning Tree Protocol (RSTP) support, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DNS proxy, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, 3G/4G USB Dongle Support, Direct Sequence Spread Spectrum (DSSS), static routing, Class of Service (CoS), IGMP proxy, 802.1x authentication, DiffServ Code Point (DSCP) support, Internet Control Message Protocol (ICMP), SSID to VLAN mapping
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.3d, IEEE 802.11e, IEEE 802.11n, UPnP, IEEE 802.11ac
DC 12 V 3 A
Asia Pacific, Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
Triple DES, AES, WPA, WPA2, WPA2-PSK, WPA2-Enterprise, WEP
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.3d, IEEE 802.11e, IEEE 802.11n, UPnP, IEEE 802.11ac, IC, FCC
Status Indicators
Power, WAN, LAN, wireless, USB, VPN, Internet, DSL
Line Properties
Line Coding Format
OFDM
Communications
SIP, ADSL2+, VDSL2
Cellular Protocol
LTE
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 , USB: 1 x
Aerial
Aerial
Internal
Antenna Qty
4
Gain Level
2 dBi
External power adapter
DC 12 V
Electric Current Required
3 A
Limited warranty - lifetime
10 - 85% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: Cisco
Price Range Ex VAT: 100 - 150
