Cisco Small Business RV130W Wireless Router 802.11b/g/n - Desktop/Wall-Mountable
Quicklinx: BJ41WS00 Mfr#: RV130W-E-K9-G5
  • IEEE 802.11n
£115.58 ex VAT
£138.69 inc VAT
The Cisco RV130W Wireless-N Multifunction VPN Router is an easy-to-use, flexible, high-performance device well suited for small businesses. It delivers highly secure, broadband, wired and wireless connectivity to small offices and remote employees. It can also be used either as a standalone wireless router, access point, bridge or repeater for flexible deployments, offering investment protection as your business needs evolve.
  • Highly secure broadband connectivity, high-speed wireless networking, and remote access
    The Cisco RV130W Multifunction VPN Router delivers highly secure broadband connectivity, high-speed wireless networking, and remote access for multiple offices and remote workers. Built for maximum flexibility, it delivers a comprehensive combination of business-class features and ease of use in a scalable solution.
  • 4-port Gigabit Ethernet managed switch
    The Cisco RV130W features a built-in 4-port Gigabit Ethernet managed switch that lets you connect network devices and transfer files and data at high speed, providing the power and performance you need to keep multiple employees productive. Intelligent quality of service (QoS) features let you prioritize network traffic to keep critical network applications like voice and video running at their best.
  • Untethered connectivity
    To provide untethered connectivity to employees throughout the office, the Cisco RV130W also includes support for wireless-N technology. This multifunction device can serve either as a wireless router, wireless access point, wireless bridge, or repeater, providing investment protection and flexibility when business needs change. You can get started using the RV130W in the way that best meets your needs, then change modes, and repurpose the solution as your business and network grow, resulting in maximum return on your technology investment.
  • Enterprise-class encryption and authentication
    For employees who need to connect from home, on the road, or from remote offices, the Cisco RV130W features integrated enterprise-class encryption and authentication, including support for IPsec and Point-to-Point Tunneling Protocol (PPTP) VPN client connections and IPsec gateway-to-gateway VPN tunnels. Advanced virtual network support lets you set up wireless guest access hotspots to provide highly secure connectivity to clients and visitors.
  • Simple configuration and easy set up
    Easy to set up and use right out of the box, both solutions feature simple wizard-based configuration to get you up and running in minutes.
  • 3G and 4G WAN failover connectivity
    Cisco RV130W has a USB port to enable 3G and 4G WAN failover connectivity that is also perfect for remote regions or temporary connectivity. This multi-use router is a cost-effective way to provide business-class performance, security, and reliability your employees need today, with the flexibility to change as your business evolves.
Cisco Small Business RV130W - wireless router - 802.11b/g/n - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
NAT throughput: 800 Mbps , VPN throughput (IPSec): 50 Mbps
Concurrent sessions: 12000 , Gateway to gateway IPSec VPN Tunnels: 10 , Client to gateway IPSec VPN tunnels: 10 , PPTP VPN tunnels: 10 , Wireless clients: up to 64
Jumbo Frame Support
9000 bytes
Network / Transport Protocol
PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 3, HTTP, HTTPS
DMZ port, NAT support, hardware encryption, PAT support, VLAN support, repeating mode, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Access Point operational mode, firmware upgradable, Rapid Spanning Tree Protocol (RSTP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Multiple SSID support, DNS proxy, HTTP proxy, port forwarding, wireless bridge mode, reset button, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, SNMP trap, DHCP client, NTP time synchronisation, Class of Service (CoS), IGMP proxy, security lock slot (cable lock sold separately), DiffServ Code Point (DSCP) support, PPTP passthrough, L2TP passthrough
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
Indonesia, Vietnam, Hong Kong, Thailand, Malaysia, Singapore, India, Philippines, Korea, Russia, Europe
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Performance
Jumbo Frame Support
9000 bytes
Routing Protocol
SNMP 3, HTTP, HTTPS
Encryption Algorithm
DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, SHA-1, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, IC
Status Indicators
Power, WAN, LAN, wireless, USB, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
Gain Level
2 dBi
External power adapter
1 x network cable
OS Provided
Linux
Software Included
Drivers & Utilities
Limited warranty - lifetime
10 - 85% (non-condensing)
BJ41 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.50
BJ41 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.04
BJ41 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.70
BJ41 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.63
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: Cisco
Price Range Ex VAT: 100 - 150
