Cisco Small Business Pro SRP 541W Wireless Router
Quicklinx: 7TG6WS00 Mfr#: SRP541W-E-K9
  • IEEE 802.11n
Demand for managed services is expected to grow dramatically, with small businesses - those with fewer than 100 employees - expected to make up more than half of this market opportunity. These companies may have complex IT needs but generally don't have the technical staff or expertise needed to keep up. They look to service providers for a flexible infrastructure and simplified management, along with better quality and reliability than they can achieve in-house. To meet this opportunity, service providers are transforming their networks, using services-ready platforms to deliver an array of profitable IP-based communications services.
Cisco SRP 500 series Services Ready Platform is a flexible, cost-effective fixed-configuration customer premises equipment (CPE) with embedded intelligence to enable service providers to create, provision, and deploy premium revenue-generating services to small businesses on an as-needed basis. This platform will help enable service providers to deliver differentiated, converged service offers that increase bandwidth usage and average revenue per user while reducing customer churn.
  • Embedded intelligence
    Embedded intelligence supports concurrent, premium revenue-generating services such as voice, data, security, and applications. Service providers can easily create and provision a variety of service offerings, adding or removing them remotely as their customers' needs change.
  • Industry-leading SIP stack
    Industry-leading SIP stack delivers an advanced implementation of standard voice coding algorithms for clear, high-quality voice under diverse network conditions, along with support for common telephony features such as voice mail, fax, and interactive voice response systems.
  • Interoperability
    Interoperability with industry-leading soft switches and voice gateways enable service providers to deploy highly efficient, scalable end-to-end multi-service networks.
  • Standards-based provisioning
    Standards-based provisioning, with support for TR-069, TR-104, and XML, that reduces operating expenses by enabling zero touch deployments, eliminating the need for highly skilled technicians and costly truck rolls to deploy new services.
  • Compact design
    Compact design integrates voice, data, switching, wireless, security, and application support in a desktop device that is ideal for simple, space-saving small business deployments.
Cisco Small Business SRP541W - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Virtual interfaces (VLANs): 10 , IPSec VPN tunnels: 5
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, static IP routing, GRE, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP v2
Telephony Interfaces
1 line (FXO), 4 phone (FXS)
Firewall protection, DHCP support, NAT support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, DiffServ support, MAC address filtering, Broadcast Storm Control, VPN passthrough, High Availability, URL filtering, firmware upgradable, Low-latency queuing (LLQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
AC 120/230 V
Enclosure Type
Desktop
Wireless, wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, ETSI, CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, AS/NZS 60950-1, RSS-210, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, CS-03, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, FCC CFR47 Part 15, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 386
RAM
64 MB
Flash Memory
32 MB
Status Indicators
Power, phone, WLAN, WAN, LAN
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP v2
Voice Codecs
G.711, G.723.1, G.729ab, G.726, T.38
IP Telephony Features
Echo cancellation, comfort noise generation (CNG), voice activity detection (VAD), call forwarding, Caller ID, call waiting, call hold, call transfer, silence suppression, DTMF generation/detection
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 1 x FXO - RJ-11 , Phone line: 4 x FXS - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
2.2 dBi
External power adapter
AC 120/230 V
1 x network cable , 1 x phone cable
5 - 95% (non-condensing)
