The Cisco WAP121 is a sleek, affordable, and easy to deploy wireless access point that delivers fast, reliable wireless connectivity and enables small businesses to easily expand their wired networks. The device combines ease of use with business-class features such as support for IPv6, Power over Ethernet for simpler deployment, quality of service to prioritize network traffic, and advanced security to deliver the reliability and performance needed for small business networks. The sleek and elegant design with flexible mounting options allows it to seamlessly blend into any small business environment. The Single Point Setup feature makes deployment of multiple access point easy, and cost effective. It can be managed with an intuitive browser-based GUI or embedded setup wizard.
- Cisco Small Business WAP121 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 12 V
- 12.4 cm x 12.4 cm x 3.5 cm
- 168 g
- Limited lifetime warranty
- 12.4 cm
- 12.4 cm
- 3.5 cm
- 168 g
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Spread Spectrum Method
- OFDM
- DHCP, Bonjour
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, WLAN, LAN
- DHCP support, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
- Antenna
- Internal
- Gain Level
- 2 dBi
- 1 x 100Base-TX (PoE) - RJ-45
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- FCC Class B certified, IC
- PoE
- Power Device
- External power adapter
- Voltage Required
- DC 12 V
- OS Provided
- Linux
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
