Your basket is empty
Cisco SG500XG-8F8T 16 port 10 Gig Managed Switch
Quicklinx: C9YPWS00 Mfr#: SG500XG-8F8T-K9-G5
The Cisco 500 series stackable managed switch provides the ideal technology foundation for demanding business networks. It offers the perfect mix of advanced features needed to ensure the availability of critical applications.
Now you can protect business information and provide a solid foundation for your current business applications, as well as those you are planning for the future-all in a package you can afford.
Cisco Small Business SG500XG-8F8T - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
8 x 10GBase-T + 8 x 10 Gigabit SFP+
Performance
Forwarding performance (64-byte packet size): 238.1 Mpps , Switching capacity: 320 Gbps , Stateful throughput: 10 Gbps
IPv4 routes: 2048 , IPv6 routes: 2048 , ACL rules: 3072
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-2, VRRP, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, Layer 2 switching, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), LACP support, LLDP support, DHCP relay, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Class of Service (CoS), Strict Priority (SP), Generic Attribute Registration Protocol (GARP), 16MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 35 cm x 4.4 cm
5.25 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
X ARM: 800 MHz
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
8 x 10GBase-T RJ-45 , 8 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial DB-9
Internal power supply
1 x serial cable
MTBF
131,290 hour(s)
UL 60950, FCC Part 15 A, CSA 22.2
Europe
44 cm
35 cm
4.4 cm
5.25 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
C9YP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
C9YP C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
C9YP C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
C9YP C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
