The Cisco 500 series stackable managed switch provides the advanced capabilities you need to support a more demanding network environment, at an affordable price. It is designed to protect your technology investment as your business grows. Unlike switches that claim to be stackable but have elements which are administered and troubleshot separately, the Cisco 500 series provides true stacking capability, allowing you to configure, manage, and troubleshoot multiple physical switches as a single device and more easily expand your network. The Cisco 500 series switch is fanless making it one of the industry's first in stackable switches, thereby delivering increased reliability, power efficiency, and minimizing noise.
High reliability and resiliency
The Cisco 500 series supports dual images, allowing you to perform software upgrades without having to take the network offline or worry about the network going down during the upgrade. -
Simplified IT operation
Cisco 500 series switch helps optimize your IT operations with built-in features that simplify and streamline day-to-day network operation. -
True stacking
Cisco 500 series switch provides true stacking capability, allowing you to configure, manage, and troubleshoot all switches in a stack as a single unit, with a single IP address. -
Strong security
Cisco 500 series switch provides the advanced security features you need to protect your business data and keep unauthorized users off the network. -
Network-wide automatic voice deployment
Using a combination of CDP, LLDP-MED, auto smartports, and VSDP (Voice Services Discovery Protocol - a unique Cisco protocol), customers can deploy an end-to-end voice network dynamically. -
High-power Power over Ethernet Plus (PoE+)
Cisco 500 series switch supports the Power over Ethernet Plus (PoE+) standard (IEEE 802. at), providing up to 30 watts per port. -
IPv6 support
As the IP address scheme evolves to accommodate a growing number of network devices, the Cisco 500 series can support the transition to the next generation of networking and operating systems. -
Advanced Layer 3 traffic management
The Cisco 500 series enables a more advanced set of traffic management capabilities to help growing businesses organize their networks more effectively and efficiently. -
Power efficiency
The Cisco 500 series integrates a variety of power-saving features, providing the industry's extensive energy-efficient switching portfolio. -
Peace of mind and investment protection
Cisco 500 series switch offers the reliable performance and peace of mind you expect from a Cisco switch.
- Cisco Small Business SG500X-48MP - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 740 W
- Performance
- Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps
- Capacity
- ACL rules: up to 3072
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- RIP-2, VRRP, static IPv4 routing, static IPv6 routing, CIDR
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, Jumbo Frames support, DHCP server, MLD snooping, DAI, reset button, STP Root Guard, UDLD, DHCP relay, IP-MAC binding, Energy Efficient Ethernet, CoS, GARP, GVRP, DSCP support, 4 fans
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 35 cm x 4.4 cm
- 5.43 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 740 W
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Max Units In A Stack
- 8
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 256 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 48 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x 10GBase-X SFP+ , 2 x SFP , 1 x console DB-9 management
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- MTBF
- 307,978 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- 44 cm
- 35 cm
- 4.4 cm
- 5.43 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
