Product
Cisco SG500X-48MP 48-port Gig + 4 10-Gig Max PoE+ Switch
Quicklinx: C9YNWS00 Mfr#: SG500X-48MP-K9-G5
The Cisco 500 series stackable managed switch provides the advanced capabilities you need to support a more demanding network environment, at an affordable price. It is designed to protect your technology investment as your business grows. Unlike switches that claim to be stackable but have elements which are administered and troubleshot separately, the Cisco 500 series provides true stacking capability, allowing you to configure, manage, and troubleshoot multiple physical switches as a single device and more easily expand your network. The Cisco 500 series switch is fanless making it one of the industry's first in stackable switches, thereby delivering increased reliability, power efficiency, and minimizing noise.
  • High reliability and resiliency
    The Cisco 500 series supports dual images, allowing you to perform software upgrades without having to take the network offline or worry about the network going down during the upgrade.
  • Simplified IT operation
    Cisco 500 series switch helps optimize your IT operations with built-in features that simplify and streamline day-to-day network operation.
  • True stacking
    Cisco 500 series switch provides true stacking capability, allowing you to configure, manage, and troubleshoot all switches in a stack as a single unit, with a single IP address.
  • Strong security
    Cisco 500 series switch provides the advanced security features you need to protect your business data and keep unauthorized users off the network.
  • Network-wide automatic voice deployment
    Using a combination of CDP, LLDP-MED, auto smartports, and VSDP (Voice Services Discovery Protocol - a unique Cisco protocol), customers can deploy an end-to-end voice network dynamically.
  • High-power Power over Ethernet Plus (PoE+)
    Cisco 500 series switch supports the Power over Ethernet Plus (PoE+) standard (IEEE 802. at), providing up to 30 watts per port.
  • IPv6 support
    As the IP address scheme evolves to accommodate a growing number of network devices, the Cisco 500 series can support the transition to the next generation of networking and operating systems.
  • Advanced Layer 3 traffic management
    The Cisco 500 series enables a more advanced set of traffic management capabilities to help growing businesses organize their networks more effectively and efficiently.
  • Power efficiency
    The Cisco 500 series integrates a variety of power-saving features, providing the industry's extensive energy-efficient switching portfolio.
  • Peace of mind and investment protection
    Cisco 500 series switch offers the reliable performance and peace of mind you expect from a Cisco switch.
Cisco Small Business SG500X-48MP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps
ACL rules: up to 3072
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-2, VRRP, static IPv4 routing, static IPv6 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), DHCP relay, IP-MAC binding, Energy Efficient Ethernet, Class of Service (CoS), Generic Attribute Registration Protocol (GARP), GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 4 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 35 cm x 4.4 cm
5.43 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
48 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x 10GBase-X SFP+ , 2 x SFP , 1 x console DB-9 management
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
307,978 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
35 cm
4.4 cm
5.43 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
C9YN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
C9YN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.62
C9YN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.24
