Product
Cisco SG500-28MPP 28-port Gigabit Max PoE+ Stackable Managed Switch
Quicklinx: C9YHWS00 Mfr#: SG500-28MPP-K9-G5
The Cisco 500 series stackable managed switch provides the ideal technology foundation for demanding business networks. It offers the perfect mix of advanced features needed to ensure the availability of critical applications. Now you can protect business information and provide a solid foundation for your current business applications, as well as those you are planning for the future-all in a package you can afford.
  • High reliability and resiliency
    Keep your network up and running with advanced redundancy and availability features that reduce downtime and improve network resiliency so your business never slows down.
  • Strong security
    Advanced security features protect your business data and keep unauthorized users off your network.
  • Power-efficient
    A variety of power-saving features across all models provide one of the industry's most extensive energy-efficient switching portfolios.
  • Simplified network setup and operations
    Intuitive browser-based tools, auto-configuration and discovery, and true stacking make theses switches easy to use and manage, and simplify day-to-day network operations.
Cisco Small Business SG500-28MPP - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Forwarding performance (64-byte packet size): 41.67 Mpps , Switching capacity: 72 Gbps , Stateful throughput: 5 Gbps
IPv4 routes: 2048 , IPv6 routes: 2048 , ACL rules: 2048
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, Layer 2 switching, power over Ethernet (PoE), VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), PoE+, reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), LACP support, LLDP support, DHCP relay, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Class of Service (CoS), Strict Priority (SP), Generic Attribute Registration Protocol (GARP), 8MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25.7 cm x 4.4 cm
5.28 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
X ARM: 800 MHz
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
24 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP , 1 x serial DB-9
Internal power supply
1 x serial cable
MTBF
188,722 hour(s)
UL 60950, FCC Part 15 A, CSA 22.2
Europe
44 cm
25.7 cm
4.4 cm
5.28 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
C9YH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
C9YH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
C9YH C2G 2m Cat6a Shielded Patch - Blue In Stock £7.04
