Cisco SG350 52-port Managed Gigabit SFP Switch
Quicklinx: F05YWS00 Mfr#: SG350-52P-K9-UK
Type: Gigabit Ethernet
Ports: 52
Managed: Yes
POE: PoE+
£991.93 ex VAT
£1,190.31 inc VAT
These managed Cisco switches offer excellent performance, rich features, and ease of use. With advanced security, routing, and energy-saving technology, they deliver a solid foundation for business applications today and in the future.
  • Powerful capabilities
    In addition to advanced management, security, and quality of service, these switches deliver capabilities such as static routing, advanced threat defense, time-based access control lists, and many others.
  • Easy setup and management
    The intuitive, browser-based user interface is user friendly, with simple mode and a configuration wizard for common configurations.
  • Performance and reliability
    Designed and tested to deliver the high performance and reliability you would expect from Cisco switches, so you can enjoy speedy file transfers and keep vital business applications available.
Cisco Small Business SG350-52P - switch - 52 ports - Managed - rack-mountable
Switch - 52 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 77.38 Mpps , Forwarding performance (64-byte packet size): 104 Gbps
Active VLANs: 4096 , ACL rules: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, 24 MB packet buffer, 3 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
44 cm x 35 cm x 4.4 cm
3.81 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link/activity
48 x 1000Base-T RJ-45 375 W , 2 x 1000Base-T RJ-45/SFP , 2 x 1000Base-X SFP , 1 x console RJ-45 management , 1 x USB management
Internal power supply
1 x power cable , 1 x console cable
Rack Mounting Kit
Included
MTBF
195,746 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
35 cm
4.4 cm
3.81 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 52
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: 750 - 1000
