Cisco SG350 10 Ports Switch L3 Managed -SG350-10P-K9 UK
Quicklinx: DV5VWS00 Mfr#: SG350-10P-K9-UK
Type: Gigabit Ethernet
Ports: 10
Managed: Yes
POE: PoE+
40 in stock
£191.78 ex VAT
£230.13 inc VAT
The Cisco 350 Series, part of the Cisco Small Business line of network solutions, is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 350 Series provides the ideal combination of affordability and capabilities for small businesses and helps you create a more efficient, better-connected workforce.
  • Secure desktop connectivity
    Cisco 350 Series Switches can simply and securely connect employees working in small offices with each other and with all of the servers, printers, and other devices they use. High performance and reliable connectivity help speed file transfers and data processing, improve network uptime, and keep your employees connected and productive.
  • Secure wireless connectivity
    With its advanced security features, Power over Ethernet, Auto Smartports, QoS, VLAN, and access control features, the Cisco 350 Series Switches are the perfect foundation to add business-grade wireless to a business network.
  • Unified communications
    As a managed network solution, the Cisco 350 Series provides the performance and advanced traffic-handling intelligence you need to deliver all communications and data over a single network. Cisco offers a complete portfolio of IP telephony and other unified communications products designed for businesses.
  • Highly secure guest connectivity
    Cisco 350 Series Switches let you extend highly secure network connectivity to guests in a variety of settings, such as a hotel, an office waiting room, or any other area open to nonemployee users. Using powerful but easy-to-configure security and traffic segmentation capabilities, you can isolate your vital business traffic from guest services and keep guests' network sessions private from each other.
Cisco Small Business SG350-10P - switch - 10 ports - Managed
Switch - 10 ports - L3 - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
62 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
Active VLANs: 4096
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, 12MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
27.9 cm x 17 cm x 4.45 cm
1.19 kg
United Kingdom
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
62 W
Performance
Active VLANs: 4096
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link/activity
8 x 1000Base-T RJ-45 PoE+ - 62 W , 2 x 1000Base-T RJ-45/SFP PoE - 60 W , 1 x console RJ-45 management , 1 x USB management
External power adapter
84.7 Watt
1 x console cable
Rack Mounting Kit
Included
MTBF
205,647 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
27.9 cm
17 cm
4.45 cm
1.19 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 10
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: 150 - 300
