Cisco SG250-26 26-PORT
Quicklinx: D0L9WS00 Mfr#: SG250-26-K9-UK
Type: Gigabit Ethernet
Ports: 26
Managed: Yes
12 in stock
£197.53 ex VAT
£237.03 inc VAT
The Cisco 250 series is the next generation of affordable smart switches that combine powerful network performance and reliability with the essential network management features you need for a solid business network. These expandable Fast Ethernet or Gigabit Ethernet switches provide basic management, security, and quality-of-service (QoS) features beyond those of an unmanaged or consumer-grade switch, at a lower cost than managed switches. And with an easy-to-use web user interface, Auto Smartports, and flexible Power over Ethernet (PoE) Plus capability, you can deploy and configure a complete business network in minutes.
  • High-speed desktop connectivity
    Cisco 250 series switches can quickly and securely connect employees working in small offices with one another and with all of the printers, servers, and other devices they use. High performance and reliable connectivity help speed up file transfers and data processing, improve network uptime, and keep your employees productive.
  • Flexible wireless connectivity
    Cisco 250 series switches work with Cisco and third-party wireless solutions to extend the reach of your network. With security features, Power over Ethernet (PoE), VLAN, and QoS, these switches are the perfect foundation to add business-grade wireless to a network.The capability of up to 30 W of power per port provided through the Ethernet cable means you can easily deploy innovative 802.11ac wireless technology to maximize workforce productivity.
  • Unified communications
    The Cisco 250 series provides QoS features to enable you to prioritize delay-sensitive traffic in your network and let you converge all of your communications solutions such as IP telephony and video surveillance onto a single Ethernet network. Cisco offers a complete portfolio of IP telephony and other unified communications products designed for small businesses, and Cisco 250 series switches have been rigorously tested to help ensure easy integration and full compatibility with these and other vendor products.
Cisco 250 Series SG250-26 - switch - 26 ports - smart - rack-mountable
Switch - 26 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 52 Gbps , Forwarding performance (64-byte packet size): 38.69 Mpps
MSTP instances: 8 , Active VLANs: 256 , QoS hardware queues: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMP, static IPv4 routing
Remote Management Protocol
SNMP, RMON, HTTP, HTTPS, TFTP, SCP
DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), MLD snooping, reset button, LLDP support, 12MB packet buffer, Storm Control, SmartPort technology, Cisco Discovery Protocol
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 20.2 cm x 4.4 cm
2.72 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
X ARM: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link/activity
24 x 1000Base-T RJ-45 , 2 x 1000Base-T RJ-45/SFP , 1 x USB management
Internal power supply
1 x power cable
MTBF
343,593 hours
UL 60950, CSA 22.2, FCC CFR47 Part 15 A
United Kingdom
44 cm
20.2 cm
4.4 cm
2.72 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 26
Managed: Yes
Brand: Cisco
Price Range Ex VAT: 150 - 300
