Cisco SG200-50 48-port 10/100/1000
Installation required? Contact us today!
Quicklinx: 7BMZWS00 Mfr#: SLM2048T-UK
Type: Gigabit Ethernet
Ports: 50
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£405.24 ex VAT
£486.28 inc VAT
The key to succeeding in today's competitive business environment is investing resources wisely and getting the most value for your dollars. What if you could achieve business-class security and performance in your small business network without paying for advanced network features your network may not need? Now you can with Cisco 200 series smart switch. When you need to share network resources and connect computers, printers, and servers, but low cost is a top priority, Cisco 200 series switch provides the ideal solution.
  • The business network you need, at an affordable price
    The Cisco 200 series is a portfolio of affordable smart switches that combine powerful network performance and reliability with the entry-level managed switch features you need for a business network.
  • Simplify setup and management
    Cisco 200 series switch is designed to be easy to configure, manage, and troubleshoot, allowing you to focus on your business priorities.
  • Gain enhanced features at the right price
    Cisco 200 series switch offers essential Layer 2 switch features at a much lower price than advanced managed switches.
  • Protect your business investment
    Cisco 200 series switch offers the reliable performance, investment protection, and peace of mind you expect from a Cisco switch.
  • A powerful foundation for the basic business network
    Cisco 200 series smart switch helps you build a business-class network for an affordable price. It provides just the right security, management, and QoS features you need to make the most of your business applications and productivity tools, without the costs or complexity of a managed switch.
Cisco Small Business Smart SG200-50 - switch - 50 ports - Managed - rack-mountable
Switch - 50 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 74.41 Mpps , Forwarding performance (64-byte packet size): 100 Gbps
MAC Address Table Size
8000 entries
Jumbo Frame Support
Remote Management Protocol
RMON, HTTP, TFTP
Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 25.7 cm x 4.4 cm
3.95 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8000 entries
Jumbo Frame Support
RMON, HTTP, TFTP
Encryption Algorithm
MD5
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, link/activity
50 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Mounting Kit
Included
MTBF
237,610 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
25.7 cm
4.4 cm
3.95 kg
Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 50
Managed: Yes
POE: No
Brand: Cisco
Price Range Ex VAT: 300 - 500
