The Cisco industry-standard 1000BASE-T Small Form-factor Pluggable (SFP) gigabit interface converter (GBIC) is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network. The Cisco SFP provides full-duplex Gigabit Ethernet connectivity to high-end workstations and between wiring closets over existing copper network infrastructure.
- Cisco - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- 1.4 cm x 7.1 cm x 1.4 cm
- 90 days warranty
- Designed For
- Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 93108TC-EX, 93180YC-FX, 9372PX-E
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- 1GbE
- 1 Gbps
- 1 x Ethernet 1000Base-T - RJ-45
- Compatible Slots
- 1 x SFP (mini-GBIC)
- NEBS level 3
- 1.4 cm
- 7.1 cm
- 1.4 cm
- Limited warranty - 90 days
- 0 °C
- 70 °C
- Designed For
- Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Nexus 93108TC-EX, 93180YC-FX, 9372PX-E
