Cisco SFP (mini-GBIC) transceiver module 1000Base-SX 1 Gbps
Quicklinx: C13KWS00 Mfr#: SX-SFP-1G-C
The Cisco Meraki MA-SFP-1GB-LX10 SFP is a 1000BASE-LX10 SFP designed to be compatible with the MS220, MS320, and MS420 families.
ProLabs - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX, Fibre Channel
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Plug-in module
Wired
Cabling Type
GigE
Fibre Channel
FC-PI
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Digital Optical Monitoring (DOM) support
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
EN 60825-1, MSA, MSA SFF-8472
-5 °C
85 °C
