The Cisco 500 Series Stackable Managed Switches are a line of stackable managed Ethernet switches that provide the advanced capabilities you need to support a more demanding network environment, at an affordable price. This switc provide 24 ports of Fast Ethernet and 24 of Gigabit Ethernet connectivity, providing a solid foundation for your current business applications, as well as those you are planning for the future. At the same time, these switches are easy to deploy and manage, without a large IT staff. Cisco 500 Series switches are designed to protect your technology investment as your business grows. Unlike switches that claim to be stackable but have elements which are administered and troubleshot separately, the Cisco 500 Series provides true stacking capability, allowing you to configure, manage, and troubleshoot multiple physical switches as a single device and more easily expand your network.
- Cisco Small Business SF500-24MP - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE+) + 2 x combo Gigabit SFP + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 375 W
- Performance
- Switching capacity: 28.8 Gbps , Forwarding performance (64-byte packet size): 9.52 Mpps
- Capacity
- ACL rules: up to 2048
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- Static IPv4 routing, static IPv6 routing, CIDR
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, Jumbo Frames support, DHCP server, MLD snooping, DAI, reset button, STP Root Guard, UDLD, DHCP relay, IP-MAC binding, Energy Efficient Ethernet, CoS, GARP, 8MB packet buffer, GVRP, DSCP support, 2 fans
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 4.35 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE+
- PoE Budget
- 375 W
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 256 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 24 x 100Base-TX RJ-45 PoE+ - 30 W , 1 x console DB-9 management , 2 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- MTBF
- 514,157 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- 44 cm
- 25.7 cm
- 4.4 cm
- 4.35 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
