Cisco Small Business 200 series smart switch combines powerful network performance with reliability to help you build a basic business network. Affordable and easy to use, these entry-level web-managed switches deliver the essential network features you need.
Enjoy speedy file transfers, keep vital business applications available, and help your employees respond faster to customers and each other.
Feature-rich capabilities
Get a business-class network with such features as quality of service, security, Power over Ethernet, and IPv6 support. -
An eco-friendly solution
Optimize power usage for efficiency without compromising performance. -
Easy setup and management
Intuitive browser-based tools simplify setup and configuration.
- Cisco Small Business Smart SF200-24 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 + 2 x combo Gigabit SFP
- Performance
- Switching capacity: 6.55 Mpps , Forwarding performance (64-byte packet size): 8.8 Gbps
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- Remote Management Protocol
- RMON, HTTP, TFTP
- Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 3.04 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- Performance
- 8000 entries
- RMON, HTTP, TFTP
- Encryption Algorithm
- MD5
- Authentication Method
- RADIUS
- RAM
- 128 MB
- Flash Memory
- 16 MB
- Status Indicators
- Port transmission speed, system, link/activity
- 24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Mounting Kit
- Included
- MTBF
- 414,166 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- Europe
- 44 cm
- 25.7 cm
- 4.4 cm
- 3.04 kg
- Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
