Cisco SF 200-24 24-PORT 10/100 SMART
Quicklinx: 7BMNWS00 Mfr#: SLM224GT-UK
Cisco Small Business 200 series smart switch combines powerful network performance with reliability to help you build a basic business network. Affordable and easy to use, these entry-level web-managed switches deliver the essential network features you need.
Enjoy speedy file transfers, keep vital business applications available, and help your employees respond faster to customers and each other.
  • Feature-rich capabilities
    Get a business-class network with such features as quality of service, security, Power over Ethernet, and IPv6 support.
  • An eco-friendly solution
    Optimize power usage for efficiency without compromising performance.
  • Easy setup and management
    Intuitive browser-based tools simplify setup and configuration.
Cisco Small Business Smart SF200-24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x combo Gigabit SFP
Performance
Switching capacity: 6.55 Mpps , Forwarding performance (64-byte packet size): 8.8 Gbps
MAC Address Table Size
8000 entries
Jumbo Frame Support
Remote Management Protocol
RMON, HTTP, TFTP
Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 25.7 cm x 4.4 cm
3.04 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
8000 entries
Jumbo Frame Support
RMON, HTTP, TFTP
Encryption Algorithm
MD5
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, link/activity
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Mounting Kit
Included
MTBF
414,166 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
25.7 cm
4.4 cm
3.04 kg
Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
7BMN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
7BMN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.13
7BMN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.45
