Small businesses are constantly exposed to Internet threats. The Cisco dual WAN Gigabit VPN routers connect small businesses to the Internet and protect employees from unwanted content and malicious websites without compromising the online experience. The routers help boost employee productivity and overall network performance by limiting Internet surfing to appropriate site categories and eliminating unwanted network traffic. Users are automatically protected from malicious or compromised websites, regardless of site categorization. End devices and applications can be identified and treated according to user-defined policies for improved productivity and optimal network usage.
PERFECT FOR BUSINESSES
High-speed Ethernet connectivity with up to 900-Mbps TCP throughput for faster downloads -
SECURITY
Robust and secure VPN: secure interconnectivity, including standard IPsec, Layer 2 Tunneling Protocol (L2TP) over IPsec, and Cisco IPsec -
CONNECTIVITY
16 ports of Gigabit for high-performance connectivity -
CONNECTIVITY
Dual WAN support allows multiple Internet connections for load balancing and failover -
PORT COUNT
2 USB ports to support a 3G/4G modem or flash drive
- Cisco Small Business RV345 - router - rack-mountable
- Router
- Enclosure Type
- Rack-mountable
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- Firewall throughput (TCP): 900 Mbps , VPN throughput (IPSec): 650 Mbps , VPN throughput (PPTP): 100 Mbps
- Capacity
- IPSec VPN connections: 50 , VLANs supported: 32
- TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, DHCP
- Routing Protocol
- RIP-1, RIP-2, GRE, RIPng
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- VoIP Protocols
- SIP
- NAT support, VPN support, PAT support, ALG support, IPv6 support, VPN passthrough, firmware upgradable, Quality of Service (QoS), IPSec passthrough, static IP mode, port forwarding, Port Security, 3G/4G USB Dongle Support, DHCP client, static routing, IGMP proxy, 802.1x authentication, PPTP passthrough, L2TP passthrough, Web Filtering
- IEEE 802.1x
- Power
- AC 120/230 V / DC 54 V
- 28 cm x 4.4 cm x 17 cm
- 1.14 kg
- Localisation
- Kuwait, Qatar, Saudi Arabia, United Arab Emirates, Indonesia, Israel, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Thailand, Malaysia, Singapore, Philippines, Europe
- Limited lifetime warranty
- Router
- Enclosure Type
- Rack-mountable
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- IEEE 802.1x, FCC Class A certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Status Indicators
- Power, DMZ, diagnostic, USB, VPN
IP Telephony
- VoIP Protocols
- SIP
- LAN: 16 x 1000Base-T - RJ-45 , WAN: 2 x 1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A , Console: 1 x RJ-45
- Installed Qty
- 1
- Voltage Required
- Rack Mounting Kit
- Included
- Localisation
- 28 cm
- 4.4 cm
- 17 cm
- 1.14 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
