Cisco RV345 Dual WAN VPN Router
Quicklinx: DXMTWS00 Mfr#: RV345-K9-G5
£200.63 ex VAT
£240.75 inc VAT
Small businesses are constantly exposed to Internet threats. The Cisco dual WAN Gigabit VPN routers connect small businesses to the Internet and protect employees from unwanted content and malicious websites without compromising the online experience. The routers help boost employee productivity and overall network performance by limiting Internet surfing to appropriate site categories and eliminating unwanted network traffic. Users are automatically protected from malicious or compromised websites, regardless of site categorization. End devices and applications can be identified and treated according to user-defined policies for improved productivity and optimal network usage.
  • PERFECT FOR BUSINESSES
    High-speed Ethernet connectivity with up to 900-Mbps TCP throughput for faster downloads
  • SECURITY
    Robust and secure VPN: secure interconnectivity, including standard IPsec, Layer 2 Tunneling Protocol (L2TP) over IPsec, and Cisco IPsec
  • CONNECTIVITY
    16 ports of Gigabit for high-performance connectivity
  • CONNECTIVITY
    Dual WAN support allows multiple Internet connections for load balancing and failover
  • PORT COUNT
    2 USB ports to support a 3G/4G modem or flash drive
Cisco Small Business RV345 - router - rack-mountable
Router
Enclosure Type
Rack-mountable
WAN Ports Qty
2
Performance
Firewall throughput (TCP): 900 Mbps , VPN throughput (IPSec): 650 Mbps , VPN throughput (PPTP): 100 Mbps
IPSec VPN connections: 50 , VLANs supported: 32
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
RIP-1, RIP-2, GRE, RIPng
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
VoIP Protocols
SIP
NAT support, VPN support, PAT support, ALG support, IPv6 support, VPN passthrough, firmware upgradable, Quality of Service (QoS), IPSec passthrough, static IP mode, port forwarding, Port Security, 3G/4G USB Dongle Support, DHCP client, static routing, IGMP proxy, 802.1x authentication, PPTP passthrough, L2TP passthrough, Web Filtering
IEEE 802.1x
AC 120/230 V / DC 54 V
28 cm x 4.4 cm x 17 cm
1.14 kg
Kuwait, Qatar, Saudi Arabia, United Arab Emirates, Indonesia, Israel, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Thailand, Malaysia, Singapore, Philippines, Europe
Router
Enclosure Type
Rack-mountable
Wired
Performance
Routing Protocol
IEEE 802.1x, FCC Class A certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
RAM
1 GB
Flash Memory
256 MB
Status Indicators
Power, DMZ, diagnostic, USB, VPN
IP Telephony
VoIP Protocols
SIP
LAN: 16 x 1000Base-T - RJ-45 , WAN: 2 x 1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A , Console: 1 x RJ-45
Installed Qty
1
Rack Mounting Kit
Included
28 cm
4.4 cm
17 cm
1.14 kg
Limited warranty - lifetime
10 - 85% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: Cisco
Price Range Ex VAT: 150 - 300
