The Cisco RV110W Wireless-N VPN Firewall combines simple, highly secure wired and wireless connectivity for small offices/home offices and remote workers with a high-speed, 802.11n wireless access point; a 4-port 10/100 Mbps Fast Ethernet switch; an intuitive, browser-based device manager; and support for the Cisco FindIT Network Discovery Utility, at a very affordable price. Its combination of business-class features, support for virtual networks to enable highly secure guest access, simple installation, and top-quality user experience takes basic connectivity for a small business with five or fewer employees to a new level.
- Cisco Small Business RV110W - wireless router - 802.11b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Performance
- NAT throughput: 90 Mbps , VPN throughput (IPSec): 5 Mbps
- Capacity
- Concurrent sessions: 5000 , IPSec VPN tunnels: 5 , PPTP VPN tunnels: 5 , Active VLANs: 4
- PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP, Bonjour, DDNS
- Routing Protocol
- RIP-1, RIP-2, IGMP, static IPv6 routing, RIPng
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- NAT support, PAT support, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, port mirroring, E-mail alert, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Rapid Spanning Tree Protocol (RSTP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support, Direct Sequence Spread Spectrum (DSSS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
- Power
- 1 A
- 15 cm x 15 cm x 3 cm
- 279 g
- Localisation
- English / Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 13
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- Triple DES, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, cUL, IC
- Status Indicators
- Power, WAN, LAN, wireless
Line Properties
- Line Coding Format
- OFDM
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 1.8 dBi
- Power Device
- External power adapter
- Electric Current Required
- 1 A
- Cables Included
- 1 x network cable
- Localisation
- English / Europe
- OS Provided
- Linux
- Software Included
- Drivers & Utilities
- 15 cm
- 15 cm
- 3 cm
- 279 g
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.11 |
