Product
Brand
Cisco Redundant Power System 2300
Quicklinx: 75BQWS00 Mfr#: C3K-PWR-750WAC=
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
Cisco - power supply - hot-plug - 750 Watt
Power supply - hot-plug - plug-in module
1.8 kg
Input Voltage
AC 100-240 V
Power Capacity
750 Watt
Input Connectors
Power IEC 60320 C13
15.2 cm x 29 cm x 4.2 cm
Catalyst 2960, 2960-24, 2960-48, 2960S-24, 2960S-48, 3560E-24, 3560E-48, 3560V2-24, 3560V2-48, 3750E-24, 3750E-48
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C13
Power Capacity
750 Watt
FCC Class A certified, BSMI, CISPR 22 Class A, GOST, CISPR 24, NOM, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZS 60950-1, CCC, FCC Part 15, MIC, UL 60950-1, IEC 60950-1, EN 60950-1
-5 °C
45 °C
10 - 85%
15.2 cm
29 cm
4.2 cm
1.8 kg
Cisco Catalyst 2960-24LC-S, 2960-24LT-L, 2960-24PC-L, 2960-24PC-S, 2960-24-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-24TT, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-48TT, 2960-48TT-L, 2960-48TT-S, 2960-8TC, 2960-8TC-S, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
