Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
- Cisco - power supply - hot-plug - 750 Watt
- Power supply - hot-plug - plug-in module
- 1.8 kg
- Input Voltage
- AC 100-240 V
- Power Capacity
- 750 Watt
- Input Connectors
- Power IEC 60320 C13
- 15.2 cm x 29 cm x 4.2 cm
- Designed For
- Catalyst 2960, 2960-24, 2960-48, 2960S-24, 2960S-48, 3560E-24, 3560E-48, 3560V2-24, 3560V2-48, 3750E-24, 3750E-48
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- Power Capacity
- 750 Watt
- FCC Class A certified, BSMI, CISPR 22 Class A, GOST, CISPR 24, NOM, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZS 60950-1, CCC, FCC Part 15, MIC, UL 60950-1, IEC 60950-1, EN 60950-1
- -5 °C
- 45 °C
- 10 - 85%
- 15.2 cm
- 29 cm
- 4.2 cm
- 1.8 kg
- Designed For
- Cisco Catalyst 2960-24LC-S, 2960-24LT-L, 2960-24PC-L, 2960-24PC-S, 2960-24-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-24TT, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-48TT, 2960-48TT-L, 2960-48TT-S, 2960-8TC, 2960-8TC-S, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
