Cisco - Power supply - hot-plug / redundant ( plug-in module ) - -36 - -72 V - 440 Watt - for Catalyst 3560X-24, 3560X-48, 3750X-12, 3750X-24, 3750X-48
- Cisco - power supply - hot-plug / redundant - 440 Watt
- Power supply - hot-plug / redundant - plug-in module
- 1.2 kg
- Input Voltage
- -36 - -72 V
- Power Capacity
- 440 Watt
- Input Connectors
- 2
- 8.3 cm x 26 cm x 3.5 cm
- Designed For
- Catalyst 3560X-24, 3560X-48, 3750X-12, 3750X-24, 3750X-48
- Input Voltage
- -36 - -72 V
- Input Connectors
- 2
- Max Electric Current
- 16 A
- Power Capacity
- 440 Watt
- BSMI, CISPR 22 Class A, GOST, CISPR 24, EN 61000-3-2, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, MIC, ICES-003 Class A, EN 61000-4-5, RoHS, UL 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, EN 300 386
- -5 °C
- 45 °C
- 5 - 90% (non-condensing)
- 8.3 cm
- 26 cm
- 3.5 cm
- 1.2 kg
- Designed For
- Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
