Product
Cisco Power Injector 11/1200 Series
Quicklinx: 3LNWWS00 Mfr#: AIR-PWRINJ3=
Cisco Aironet Power Injector products increase the deployment flexibility of Cisco Aironet wireless access points and bridges by providing an alternative powering option to local power, inline power-capable multiport switches, and multiport power patch panels.
The power injector for Cisco Aironet 1100 and 1200 series access points (AIR-PWRINJ3) works with the power supply provided with the access point.
Cisco Aironet Power Injector - PoE injector
PoE injector - external
0.1 kg
Input Voltage
48 V
Output Voltage
48 V
Output connectors
1 x RJ-45
13.9 cm x 5.4 cm x 3.5 cm
Aironet 1100, 1130AG, 1200, 1230AG, 1232AG, 1242AG
Input Voltage
48 V
1 x RJ-45
Output Voltage
48 V
1 x LAN - RJ-45
10 - 90%
13.9 cm
5.4 cm
3.5 cm
0.1 kg
Cisco Aironet 1100, 1130AG, 1200, 1230AG, 1232AG, 1242AG
