Cisco Power Cable for Catalyst 3850-24
Quicklinx: 9DQLWS00 Mfr#: CAB-TA-UK=#21013477_Rev0
Length: 2.44m
£40.15 ex VAT
£48.18 inc VAT
Cisco pays special attention to its network accessories which are the foundation stone of the whole network system. Cisco cables, adapters and other accessories will never let you down and you can always rely on the superior quality and outstanding reliability. Cisco has a wide range of network cables that will fit even the most extraordinary demands.
  • Robust compatibility
    Designed specifically for PC use, this power cable ensures seamless connectivity and performance, making it an essential accessory for your computing needs.
  • High-quality construction
    Featuring a power IEC 60320 C15 connector on one end and a power BS 1363 connector on the other, this cable is built for durability and reliability, capable of handling AC 250 V with ease.
Cisco - power cable - IEC 60320 C15 to BS 1363 - 2.44 m
Power cable
Length
2.44 m
United Kingdom
Connector
Power IEC 60320 C15
Connector (Second End)
Power BS 1363 - male
Rated Voltage
AC 250 V
Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9200L, 9300L
Power cable
Rated Voltage
AC 250 V
Length
2.44 m
United Kingdom
Connector
Power IEC 60320 C15
Cisco Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9200L, 9300L
Length: 2.44m
Brand: Cisco
