Your basket is empty
Cisco IP Phone Power Injector For 79
Quicklinx: 771MWS00 Mfr#: CP-PWR-INJ=
The Cisco Unified IP Phone Power Injector is a midspan power injector designed and tested for use with Cisco Unified IP phones. The Cisco Unified IP Phone Power Injector sits between a switch port and the Cisco Unified IP phone, providing inline power capability to an unpowered switch port. It supports Cisco midspan power, IEEE 802.3af modes for supplying power to the attached phone, and 10/100/1000BASE-T Ethernet connections.
Cisco Unified IP Phone Power Injector - PoE injector - 15.5 Watt
PoE injector - external
300 g
Output Voltage
-48 V
Power Capacity
15.5 Watt
11.8 cm x 13.8 cm x 4.1 cm
IP Phone 7902G, 7905, 7905G, 7906G, 7910, 7910+SW, 7910G, 7910G+SW, 7911G, 7914, 7920, 7935, 7940, 7940G, 7941G-GE, 7960, 7960G, 7961G, 7961G-GE, 7970G, 7971G-GE, 7985G, 7985G NTSC, 7985G PAL; Unified IP Phone 7912G, 7941G
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
-48 V
Power Capacity
15.5 Watt
2 x Gigabit LAN - RJ-45
FCC Class B certified, VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC CFR47 Part 15
10 - 95%
11.8 cm
13.8 cm
4.1 cm
300 g
Cisco IP Phone 7902G, 7905, 7905G, 7906G, 7910, 7910+SW, 7910G, 7910G+SW, 7911G, 7914, 7920, 7935, 7940, 7940G, 7941G-GE, 7960, 7960G, 7961G, 7961G-GE, 7970G, 7971G-GE, 7985G, 7985G NTSC, 7985G PAL , Cisco Unified IP Phone 7912G, 7941G
