The Cisco IP Phone 8811 is a cost-effective, business-class collaboration endpoint that delivers high-fidelity, reliable, secure and scalable voice communications for midsize to large enterprise businesses.
With the Cisco IP Phone 8811, you can increase personal productivity through an engaging user experience that is both powerful and easy-to-use. The IP Phone 8811 combines an attractive ergonomic design with wideband audio for crystal clear voice communications, "always-on" reliability, encrypted voice communications to enhance security and access to a comprehensive suite of unified communications features from Cisco communication servers.
The Cisco IP Phone 8811 supports five programmable line keys. You can configure keys to support either multiple directory numbers or calling features such as speed dial. You can also boost productivity by handling multiple calls for each directory number, using the multicall-per-line feature. Fixed-function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. Backlit acoustic keys provide flexibility for audio path selection and switching.
The Cisco IP Phone 8811 offers a 5-in. high-resolution (800 x 480) widescreen backlit grayscale display. Localized language support, including right-to-left on-screen text, meets the needs of global users.
The phone supports a built-in Gigabit Ethernet switch for your PC connection.
LARGE DISPLAY
5-inch high-resolution widescreen greyscale display with localised language support to meet the needs of global users -
FIXED FUNCTION KEYS
One-touch access to service, messaging, directory, hold/resume, transfer and conference features -
FULLY PROGRAMMABLE
Set up line keys to support either lines, such as directory numbers, or call features like speed dialling -
OPTIMAL PERFORMANCE
Class 2 PoE with a built-in Ethernet Gigabit switch for your PC connection -
PEACE OF MIND
1-year limited hardware warranty
 - Cisco IP Phone 8811 - VoIP phone
- Product Type
 - VoIP phone
- Compatible Platforms
 - Cisco Business Edition 6000
- Main Features
 - Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
 - SIP, RTCP, RTP, SRTP, SDP
- Voice Codecs
 - G.722, G.729a, G.711u, G.711a, iLBC, iSAC
- Lines Supported
 - 5 lines
- Intercom
- Speakerphone
 - Yes (digital duplex)
- Call Services
 - Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
- Display
 - LCD display - monochrome - Yes
- Network Ports Qty
 - 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
 - Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Communications Manager Express 10.0 or later
 - 1-year warranty
- Product Type
 - VoIP phone
- Body Material
 - ABS plastic
Phone Features
- Call Services
- Dialer Type
 - Keypad
- Dialer Location
 - Base
- Conference Call Capability
- Intercom
- Speakerphone
- Menu Operation
- Programmable Buttons Qty
 - 5
- Indicators
 - Voice message waiting indicator, speakerphone indicator, headset
- Firmware Upgradable
- Additional Functions
 - Call timer, Intercom
- Additional Features
 - Music on hold, BLF status lamps
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- Voice Codecs
- Lines Supported
 - 5 lines
- Quality of Service
 - IEEE 802.1Q (VLAN), IEEE 802.1p
- Security
 - IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
 - IP, TFTP, UDP, Cisco Discovery Protocol (CDP), HTTP, DNS, HTTPS, SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP
- Network Ports Qty
- Network Features
 - Class 2 PoE
Display
- Display Location
 - Base
- Diagonal Size
 - 5"
- Display Resolution
 - 800 x 480 pixels
- Backlit
- Display Languages
 - Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
- Connections
 - Headset jack / RJ-9 , Electronic hook switch (EHS)
- Hearing Aid Compatible
- Placing / Mounting
 - Wall-mountable, table mount
 - ADA, HAC (Hearing Aid Compatible)
Dimensions & Weight (Base)
 - 25.734 cm
 - 4 cm
 - 22.91 cm
 - 1.17 kg
 - Limited warranty - replacement - 1 year
