The Cisco Industrial Ethernet 3000 (IE 3000) Series Switches are a new family of switches that provide a rugged, easy-to-use, secure switching infrastructure for harsh environments. The Cisco IE 3000 family features industrial design and compliance, tools for ease of deployment, management, and replacement; and network security based on open standards. The Cisco IE 3000 is an ideal product for industrial Ethernet applications, including factory automation, intelligent transportation systems (ITSs), substations, and other deployments in harsh environments.
- Cisco Industrial Ethernet 3000 Series - switch - 8 ports - Managed
- Switch - 8 ports - L2+ - Managed
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 + 2 x combo Gigabit SFP
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2
- Layer 2 switching, VLAN support, IGMP snooping, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI)
- IEEE 802.1D, IEEE 802.3ad (LACP), IEEE 802.1x
- 15.2 cm x 11.2 cm x 14.7 cm
- 2 kg
- 1-year warranty
- Enclosure Type
- DIN rail mountable
- Subtype
- Fast Ethernet
- Ports
- 8K entries
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 128 MB
- Flash Memory
- 64 MB Flash
- Status Indicators
- Port status, system
- 8 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Rack Mounting Kit
- Optional
- MTBF
- 329,451 hours
- UL, BSMI CNS 13438 Class A, CISPR 24, cUL, EN55022, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, NOM, VCCI Class A ITE, IEC 60950, EN55024, CISPR 22, CB, MIC, AS/NZS 3548, EN 50081-2, EN 50082-2, UL 60950-1, IEC 60950-1, CSA C22.2 No. 60950-1-03, UL 508, FCC Part 15 A, CSA C22.2 No. 60950-1
- Software Included
- Cisco IOS LAN Base
- 15.2 cm
- 11.2 cm
- 14.7 cm
- 2 kg
- Limited warranty - 1 year
- -40 °C
- 75 °C
- 10 - 95%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £7.89 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.40 |
Cisco 1000BASE-LX/LH SFP Transceiver | In Stock | £464.19 |
Cisco - Power supply ( DIN rail mountable ) - AC 110-220/ DC 88-300 V | In Stock | £294.71 |
