Cisco Gigabit Ethernet LH Mini-GBIC SFP Transceiver
Quicklinx: 5L9GWS00 Mfr#: MGBLH1
£179.27 ex VAT
£215.12 inc VAT
Cisco MGE Small Form-Factor Pluggable (SFP) transceiver is an easy-to-install module that provides a simple way to add fiber connectivity or to add an extra Gigabit Ethernet port to your Cisco Small Business switches.
The Cisco MGE transceiver provides fast and reliable connectivity between switches that are located on different floors, in separate buildings, or on a small campus network needing connectivity between sites. This transceiver can support both Fast and Gigabit Ethernet applications.
  • ADDS FIBER
    Optic connectivity to Cisco 100 to 500 Series switches
  • CONNECTIVITY
    1000BASE-LH SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 40 km
  • DURABLE AND LOW POWER CONSUMPTION
    Less power usage and heat-conducting increases the life of the product
  • EASY TO USE
    Easy installation, plug and play, fully hot-swapple
  • PEACE OF MIND
    5-year warranty and one-year technical support
Cisco Small Business MGBLH1 - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-LH
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
40 km
250 Series; Business 110 Series; 220 Series; 350 Series; Small Business SF 100-16, SF 100D-05, SF 100D-08, SF 100D-16, SF 100D-16 V2, SF 102-24, SF110, SF112, SF300, SF302, SF350, SF352, SF500, SG 100-16, SG 100-24, SG 100D-05, SG 100D-08, SG 102-24, SG110, SG112, SG250, SG300, SG350, SG355, SG500
Plug-in module
Wired
Cabling Type
1000Base-LH
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
40 km
1 x Ethernet 1000Base-LH - LC x 2
Compatible Slots
1 x SFP (mini-GBIC)
Cisco 250 Series SG250X-48P , Cisco Business 110 Series 110-24T, 110-8T-D , Cisco Business 220 Series CBS220-24P-4X , Cisco Business 350 Series 350-24FP-4G, 350-24T-4G, 350-8T-E-2G, CBS350-48T-4G , Cisco Small Business SF 100-16, SF 100-24, SF 100D-05, SF 100D-08, SF 100D-08P, SF 100D-16, SF 100D-16 V2, SF 100D-16P, SF 102-24, SF110-16, SF110-24, SF110D-05, SF110D-08, SF110D-08HP, SF110D-16, SF110D-16HP, SF112-24, SF300-08, SF300-24, SF300-24MP, SF300-24P, SF300-24PP, SF300-48, SF300-48P, SF300-48PP, SF302-08, SF302-08MP, SF302-08MPP, SF302-08P, SF302-08PP, SF350-08, SF350-24, SF350-24MP, SF350-24P, SF350-48, SF350-48MP, SF350-48P, SF352-08, SF352-08MP, SF352-08P, SF352-08P-K9, SF500-24, SF500-24MP, SF500-24P, SF500-48, SF500-48MP, SF500-48P, SG 100-16, SG 100-24, SG 100D-05, SG 100D-08, SG 100D-08P, SG 102-24, SG110-16, SG110-16HP, SG110-24, SG110-24HP, SG110D-05, SG110D-08, SG110D-08HP, SG112-24, SG250-08, SG250-08HP, SG250-10P, SG250-18, SG250X-24, SG250X-24P, SG250X-48, SG250X-48P, SG300-10, SG300-10MP, SG300-10MPP, SG300-10P, SG300-10PP, SG300-10SFP, SG300-20, SG300-24PP, SG300-28, SG300-28MP, SG300-28P, SG300-28PP, SG300-28SFP, SG300-52, SG300-52MP, SG300-52P, SG350-10, SG350-10MP, SG350-10P, SG350-10SFP, SG350-20, SG350-28, SG350-28MP, SG350-28P, SG350-28SFP, SG350-52, SG350-52MP, SG350-52P, SG350-8PD, SG350X-12PMV, SG350X-24, SG350X-24MP, SG350X-24P, SG350X-24PD, SG350X-24PV, SG350X-48, SG350X-48MP, SG350X-48P, SG350X-48PV, SG350X-8PMD, SG350XG-24F, SG350XG-24T, SG350XG-2F10, SG350XG-48, SG350XG-48T, SG355-10P, SG500-28, SG500-28MPP, SG500-28P, SG500-52, SG500-52MP, SG500-52P, SG500X-24, SG500X-24MPP, SG500X-24P, SG500X-48, SG500X-48MP, SG500X-48P, SG500XG-8F8T
