Product
Brand
Cisco Gigabit Ethernet BX Mini-GBIC SFP Transceiver
Quicklinx: 7TJ2WS00 Mfr#: MGBBX1
The Cisco MGE transceivers provide fast and reliable connectivity between switches that are located on different floors, in separate buildings, or on a small campus network needing connectivity between sites. These transceivers can support both Fast and Gigabit Ethernet applications.
Cisco Small Business MGBBX1 - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000BASE-BX20-U
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 (TX) / 1490 (RX) nm
GigE
Max Transfer Distance
40 km
1.3 cm x 5.6 cm x 0.9 cm
18 g
Plug-in module
Wired
Cabling Type
1000BASE-BX20-U
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
40 km
1 x Ethernet 1000Base-BX20-U - LC single-mode
Compatible Slots
1 x SFP (mini-GBIC)
VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, FCC Part 15 B, EN 60825, IEC 60825-1, FDA
1.3 cm
5.6 cm
0.9 cm
18 g
70 °C
10 - 85%
