Your basket is empty
Cisco Generic Broadcom NetXtreme II 5709 - Network adapter - PCI Express x
Quicklinx: B9FZWS00 Mfr#: N2XX-ABPCI03-M3=
The Broadcom NetXtreme II 5709 Gigabit Server Adapter is able to simultaneously perform accelerated networking and storage networking on standard Ethernet. The NetXtreme II is a family of Converged Network Interface Controllers (C-NICs) with superior design. These devices also support teaming and failover to improve network application performance and provide server redundancy.
Broadcom NetXtreme II 5709 - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
Ports
Gigabit Ethernet x 4
14.7 cm x 6.4 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, IPX/SPX, NetBEUI/NetBIOS, IP/IPX, iSCSI
1 x BCM5709C - Broadcom
IEEE 802.2, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3p
Microsoft Windows Server 2003, Red Hat Enterprise Linux 4, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008
UCS B200 M3 Blade Server, C220 M3 High-Density Rack-Mount Server Small Form Factor, C240 M3 High-Density Rack-Mount Server Small Form Factor
Network adapter
PCI Express x4
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Auto-negotiation, load balancing, wake on LAN (WOL), IPv6 support, Jumbo Frames support
Processor / Memory
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4 - low-profile
ACPI 2.0
14.7 cm
6.4 cm
55 °C
Cisco UCS B200 M3 Blade Server, C220 M3 High-Density Rack-Mount Server Small Form Factor, C240 M3 High-Density Rack-Mount Server Small Form Factor
B9FZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
B9FZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
B9FZ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
B9FZ C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
