The Cisco WAP321 is a sleek, high-performance, and easy to deploy selectable band Wireless-N access point that delivers fast, reliable wireless connectivity and allows small businesses to easily expand their wired networks. This device combines ease of use with business-class features such as a Gigabit Ethernet LAN port, support for IPv6, Power over Ethernet for simpler deployment, quality of service to prioritize network traffic, and comprehensive security to deliver the reliability and performance needed for small business networks. The elegant design has flexible mounting options that allow it to seamlessly blend into any small business environment. It can be managed with an intuitive browser-based GUI.
- Cisco Small Business WAP321 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- Japan, Korea, Russia, Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 17 cm x 17 cm x 3.5 cm
- 275 g
- Limited lifetime warranty
- 17 cm
- 17 cm
- 3.5 cm
- 275 g
- Localisation
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Spread Spectrum Method
- OFDM
- DHCP, Bonjour
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, LAN, wireless
- DHCP support, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
- Antenna
- Internal
- Gain Level
- 2 dBi
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- FCC Class B certified, IC
- PoE
- OS Provided
- Linux
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
