The Cisco Unified IP Phone 7945G demonstrates the latest advances in VoIP telephony, including wideband audio support, backlit color display, and an integrated Gigabit Ethernet port. It addresses the needs of transaction-type workers with significant phone traffic and the needs of those working with bandwidth-intensive applications on co-located PCs. This IP phone includes a large, backlit, easy-to-read color display for easy access to communication information, timesaving applications, and features such as date and time, calling party name, calling party number, digits dialed, and presence information. It also accommodates Extensible Markup Language (XML) applications that take advantage of the display. The phone provides direct access to two telephone lines (or combination of lines, speed dials, and direct access to telephony features), four interactive soft keys that guide you through call features and functions, and an intuitive four-way (plus Select key) navigation cluster. A hands-free speakerphone and handset designed for high-fidelity wideband audio are standard, as is a built-in headset connection.
- Cisco Unified IP Phone 7945G - VoIP phone
- Product Type
- VoIP phone
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SCCP, SIP
- Voice Codecs
- G.722, G.729a, G.729ab, G.711u, G.711a, iLBC
- Multiline Operation Capability
- 2-line operation
- Speakerphone
- Yes (digital duplex)
- Voice Mail Capability
- Call Services
- Voice Mail
- Display
- LCD display - colour - Yes
- Display Features
- Wallpaper
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Body Colour
- Silver, dark grey
- Product Type
- VoIP phone
- Body Colour
- Silver, dark grey
- Body Material
- ABS plastic
Phone Features
- Call Services
- Voice Mail
- Dialer Type
- Keypad
- Dialer Location
- Base
- 2-line operation
- Conference Call Capability
- Speakerphone
- Menu Operation
- Function Buttons
- Speakerphone button, headset button, menu navigation keys, mute button
- Programmable Buttons Qty
- 2
- Volume Control
- Ringer Control
- Ring Tones
- 24
- Firmware Upgradable
- Additional Functions
- Web browser
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SCCP, SIP
- Voice Codecs
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- 128 bit AES
- Power Over Ethernet (PoE) Support
- Network Protocols
- TFTP
- Network Ports Qty
- Voice Features
- Echo cancellation (ECN)
- Network Features
- Class 3 PoE
Display
- Display Location
- Base
- Diagonal Size
- 5"
- Display Resolution
- 320 x 240 pixels
- Colour Depth
- 16-bit (65000 colours)
- Display Information
- Date, time
- Backlit
- Wallpaper
- Connections
- Headset jack
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
Dimensions & Weight (Base)
- 26.7 cm
- 15.2 cm
- 20.3 cm
- 1.6 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
