The Cisco 1921 builds on the best-in-class. All Cisco 1900 Series Integrated Services Routers offer embedded hardware encryption acceleration, and advanced security services. In addition, the platforms support the industry's widest range of wired and wireless connectivity options such as Serial, T1/E1, xDSL, Gigabit Ethernet, and third-generation (3G) wireless.
The Cisco 1921 is architected to meet the application demands of today's branch offices with design flexibility for future applications.
The Cisco 1921 provides significantly enhanced modular capabilities that offer you investment protection. You can easily interchange modules used on the Cisco 1921 with other Cisco routers to provide maximum investment protection. Taking advantage of common interface cards across a network greatly reduces the complexity of managing inventory requirements, implementing large network rollouts, and maintaining configurations across a variety of branch-office sizes.
Service integration
The Cisco 1921 offers increased levels of services integration with data, security, wireless, and mobility services, enabling greater efficiencies and cost savings. -
High performance with integrated services
The Cisco 1900 Series enables deployment in high-speed WAN environments with concurrent services enabled up to 15 Mbps. -
Processors
The Cisco 1921 is powered by high-performance multi-core processors that support growing demands of branch-office networks by supporting high-throughput WAN requirements. -
Integrated Gigabit Ethernet ports
All onboard WAN ports are 10/100/1000 Gigabit Ethernet WAN-routed ports.
- Cisco 1921 - router - desktop, rack-mountable
- Router
- Enclosure Type
- Desktop, rack-mountable - modular - 1U
- Data Link Protocol
- IPSec, L2TPv3
- Routing Protocol
- OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MPLS
- Remote Management Protocol
- SNMP, RMON
- Firewall protection, VPN support, MPLS support, VLAN support, Syslog support, IPv6 support, Class-Based Weighted Fair Queuing (CBWFQ), Weighted Random Early Detection (WRED), Quality of Service (QoS), Web Services Management Agent (WSMA), TR-069 Agent, NetFlow
- IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag
- Power
- AC 120/230 V (50/60 Hz)
- 34.3 cm x 29.2 cm x 4.4 cm
- 5.4 kg
- 1-year warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- IPSec, L2TPv3
- Routing Protocol
- SNMP, RMON
- IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, VCCI, CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, CAN/CSA-E60065-00, ICES-003 Class A, CS-03, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, CSA C22.2 No. 60950-1, AS/NZS 3548 Class A, EN 300 386
- RAM
- 512 MB (installed) / 512 MB (max)
- Flash Memory
- 256 MB (installed) / 256 MB (max)
- 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Serial: 1 x console , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary , USB 2.0: 1 x 4 pin USB Type A
- Expansion Slots
- 2 (total) / 2 (free) x EHWIC
- Power Device
- Internal power supply
- Voltage Required
- 60 Watt
- Rack Mounting Kit
- Optional
- OS Provided
- Cisco IOS Security
- 34.3 cm
- 29.2 cm
- 4.4 cm
- 5.4 kg
- Limited warranty - advance parts replacement - 1 year - response time: 10 days
- 0 °C
- 40 °C
- 10 - 85%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £80.54 |
