Product
Cisco Catalyst Compact Managed Switch
Quicklinx: 7ZSHWS00 Mfr#: WS-C2960CG-8TC-L
The Cisco Catalyst 2960-C series compact switch is a small form-factor Fast Ethernet and Gigabit Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, micro branch office, classroom, cruise ship, and other wiring-constrained environments.
  • Cisco borderless networks and access switching
    Borderless networks, Cisco architecture, deliver a workspace experience, connecting anyone, anywhere, using any device, to any resource - securely, reliably, and transparently. The Cisco borderless networks architecture addresses primary IT and business challenges to help create a truly borderless experience by bringing interactions closer to the employee and customer.
  • Good for business, better for environment
    Together, Cisco EnergyWise technology and Cisco Catalyst Compact switches enable greenhouse gas (GhG) emissions reduction, increased energy cost savings, and sustainable business behavior.
  • Cisco operational excellence for reducing operating costs
    Cisco Catalyst 2960-C series compact switches make deployment easy: reduce switch installation, configuration, troubleshooting time, and operational costs.
  • Advanced, intelligent network management tools
    The Cisco Catalyst 2960-C series compact switch offers both the traditional Cisco CLI for detailed configuration and Cisco Network Assistant software, a PC-based tool for quick configuration based on preset templates. In addition, CiscoWorks LAN Management Solution (LMS) supports the Cisco Catalyst 2960-C series compact switch for network-wide management.
  • CiscoWorks LAN Management Solution
    CiscoWorks LAN Management Solution (LMS) is a comprehensive network lifecycle management solution. It provides an extensive library of easy-to-use features to automate the initial and day-to-day management of your Cisco network infrastructure. CiscoWorks LMS uniquely uses Cisco hardware and software platform knowledge and operational experience into a powerful set of workflow-driven configuration, monitoring, troubleshooting, reporting, and administrative tools.
  • Borderless security
    The Cisco Catalyst compact series switch provides superior Layer 2 threat defense capabilities for mitigating man-in-the-middle attacks. TrustSec, a primary element of borderless security architecture, helps enterprise customers secure their networks, data and resources with policy-based access control, identity and role-aware networking, pervasive integrity, and confidentiality.
Cisco Catalyst Compact 2960CG-8TC-L - switch - 8 ports - Managed
Switch - 8 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x shared SFP
Performance
Forwarding performance (64-byte packet size): 13.2 Mpps , Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), STP Root Guard, Uni-Directional Link Detection (UDLD), fanless, DHCP relay, Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP)
26.9 cm x 21.3 cm x 4.4 cm
1.35 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
10 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x RS-232 - RJ-45 management , 2 x SFP (mini-GBIC)
Internal power supply
MTBF
542,482 hours
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS LAN Base
26.9 cm
21.3 cm
4.4 cm
1.35 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
7ZSH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
7ZSH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.84
7ZSH C2G 2m Cat6a Shielded Patch - Blue In Stock £7.27
7ZSH C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £46.13
