Cisco Catalyst Compact 2960C-8PC-L 8 port Switch Managed
Quicklinx: 8XYMWS00 Mfr#: WS-C2960C-8PC-L
Type: Fast Ethernet
Ports: 8
Managed: Yes
POE: PoE
£612.02 ex VAT
£734.42 inc VAT
The Cisco Catalyst 2960-C series compact switch is small form-factor Gigabit Ethernet and Fast Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
  • Cisco borderless networks and access switching
    Borderless networks, a Cisco next-generation architecture, deliver the workspace experience, connecting anyone, anywhere, using any device, to any resource - securely, reliably, transparently. The Cisco borderless networks architecture addresses primary IT and business challenges to help create a truly borderless experience by bringing interactions closer to the employee and customer.
  • Good for business, better for environment
    Together, Cisco EnergyWise technology and Cisco Catalyst compact switches enable greenhouse gas (GhG) emissions reduction, increased energy cost savings, and sustainable business behavior.
  • Cisco operational excellence: reducing operating costs
    Cisco Catalyst 2960-C series compact switche makes deployment easy: reduce switch installation, configuration, troubleshooting time, and operational costs.
Cisco Catalyst Compact 2960C-8PC-L - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, power over Ethernet (PoE), auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), STP Root Guard, Uni-Directional Link Detection (UDLD), fanless, DHCP relay, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP)
26.9 cm x 23.8 cm x 4.4 cm
1.86 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Port status, system, link/activity
2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 8 x 10Base-T/100Base-TX - RJ-45 PoE , 1 x console - mini-USB Type B management , 1 x RS-232 - RJ-45 management , 2 x SFP (mini-GBIC) , 1 x USB Type A
Internal power supply
MTBF
373,635 hours
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS LAN Base
26.9 cm
23.8 cm
4.4 cm
1.86 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
8XYM C2G 2m USB 2.0 A/B Cable - Black In Stock £4.19
8XYM C2G 5m USB 2.0 A/B Cable - Black In Stock £4.92
8XYM C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.99
8XYM C2G USB Superbooster Extender Kit In Stock £36.02
Type: Fast Ethernet
Ports: 8
Managed: Yes
POE: PoE
Brand: Cisco
Price Range Ex VAT: £500 - £750
