Product
Cisco Catalyst 6500 48-port 10/100/1000 GE Module
Quicklinx: 725ZWS00 Mfr#: WS-X6748-GE-TX=
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
  • Forwarding architecture
    These modules use the central Cisco Express Forwarding engine located on the supervisor engine; optional field-upgradable Distributed Cisco Express Forwarding daughter cards are available.
  • Fabric connection
    These modules connect to the switch-fabric channels using dual 20 Gbps switch-fabric channels.
Cisco Express Forwarding 720 Interface Module - switch - 48 ports - Managed - plug-in module
Switch - 48 ports - Managed
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Bandwidth: 720 Gbps
Jumbo Frame Support
9216 bytes
Routing Protocol
HSRP, VRRP
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP
Full duplex capability, auto-negotiation, VLAN support, Cisco Gigabit EtherChannel, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, Time Domain Reflectometry (TDR), Per-VLAN Spanning Tree Plus (PVST+), Per-VLAN Rapid Spanning Tree (PVRST)
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
35.6 cm x 40.6 cm x 3 cm
Catalyst 6503, 6503-E, 6504-E, 6506, 6506-E, 6506-E IDSM-2, 6506-E NAM-3, 6509, 6509-E, 6509-E 10Gig, 6509-E NAM-3, 6509-NEB, 6509-NEB-A, 6509-V-E, 6513, 6513 10Gig, 6513-E
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Compatible Slots
1 x Expansion Slot
Ports
48 x 10/100/1000
Performance
Bandwidth: 720 Gbps
Jumbo Frame Support
9216 bytes
Routing Protocol
HSRP, VRRP
Status Indicators
Port status, power, Boot State, fail, link/activity
48 x 1000Base-TX RJ-45
CISPR 22 Class A, CISPR 22 Class B, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55022 Class A, EN55022 Class B, AS/NZS 3260, FCC CFR21 Part 1040, FCC Part 15 A, CSA C22.2 No. 950, AS/NZS 3548 Class B, AS/NZS 3548 Class A
35.6 cm
40.6 cm
3 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
75 °C
Max Altitude Operating
4 km
Cisco Catalyst 6503, 6503 Firewall Security System, 6503 VPN System, 6503-E, 6503-E chassis with Supervisor Engine 32, 6503-E Firewall Security System Bundle, 6503-E WSLM Bundle, 6504-E, 6504-E Application Control Engine (ACE) 20 Bundle, 6504-E chassis with Supervisor Engine 32, 6504-E with Supervisor Engine 720-3B, 6504-E with WiSM Bundle, 6506, 6506 chassis, 6506 Firewall Security System, 6506 Firewall Security System with Enhanced Chassis, 6506-E, 6506-E chassis with Supervisor Engine 32, 6506-E Data Center Services Bundle, 6506-E Firewall Security System Bundle, 6506-E IDSM-2 Bundle with 2-Gbps Performance, 6506-E IPSec VPN SPA Security System Bundle, 6506-E NAM-3 System, 6506-E VPN System, 6506-E WLSM Bundle, 6509, 6509 chassis, 6509 Firewall and IDS Security System, 6509 Firewall and VPN Security System, 6509 Firewall Security System, 6509 Wiring Closet Bundle, 6509-E, 6509-E 10Gig Firewall Security System Bundle, 6509-E Application Control Engine (ACE) 20 Bundle, 6509-E Application Control Engine (ACE) 30 8G Bundle, 6509-E chassis with Supervisor Engine 32, 6509-E Data Center Services Bundle, 6509-E Firewall Security System Bundle, 6509-E Firewall Security System Bundle with Supervisor Engine 720-3BXL, 6509-E IPSec VPN SPA Security System, 6509-E NAM-3 System, 6509-E with Supervisor Engine 720, 6509-E with WiSM Bundle, 6509-NEB, 6509-NEB-A, 6509-V-E, 6513, 6513 10Gig Firewall Security System Bundle, 6513 chassis, 6513 Chassis with Supervisor Engine 32, 6513 Firewall Security System, 6513 Firewall Security System Bundle, 6513 IPSec VPN SPA Security System, 6513-E
