Establishing borderless leadership is now easier than ever to achieve with the Cisco Supervisor Engine 7-E, an enterprise-class borderless network access and aggregation supervisor engine. Cisco Supervisor Engine 7-E is built with price-performance aggregation deployments in mind, providing increased Gigabit Ethernet and 10 Gigabit Ethernet fiber density along with hardware capabilities to support enterprise-class aggregation functionalities. Supervisor Engine 7-E facilitates borderless user experiences for enterprise, public sector, mid-market, and commercial customer deployment business-critical applications.
Predictable performance and scalability
The Supervisor Engine 7-E is also optimized for multimedia applications with its advanced multicast support offered by features such as Protocol Independent Multicast (PIM), Source-Specific Multicast (SSM), and Pragmatic General Multicast (PGM), giving your network additional scalability to support multimedia applications. -
Simplified operations through automation
As campus switching has grown to support increasing enterprise demands, so has the need to deploy and manage evolving technologies. Simplified operations are critical in meeting these challenges and achieving increased operational efficiency through proactive management and reduction in unplanned network downtime. -
Optimized application visibility with flexible NetFlow
Cisco IOS flexible NetFlow allows optimization of the network infrastructure, reducing operation costs, improving capacity planning and security incident detection with increased flexibility and scalability. The Cisco Supervisor Engine 7-E enables powerful, on-box and customizable event correlation and policy actions. This allows the switches to trigger customized event alarms or policy actions when the predefined condition is met. With no external appliance required, customers are able to use existing infrastructure to perform traffic monitoring, making traffic analysis economical even on large IP network. -
IPv6 support
IPv6 is important for the future of IP networking and is critical for the expansion of IP address space in the future. IPv6 capability is required by many companies and is being mandated by governments worldwide. The Supervisor Engine 7-E supports Multicast Listener Discovery (MLD) snooping for IPv6, enhancing performance and reducing network traffic by allowing a switch to dynamically add and remove hosts from a multicast group.
- Cisco Supervisor Engine 7-E - control processor
- Control processor
- Form Factor
- Plug-in module
- Processor
- 1.5 GHz
- RAM
- 2 GB (installed) / 4 GB (max)
- Performance
- Switching capacity: 848 Gbps , Per-slot switching capacity: 48 Gbps , IPv6 routing: 125 Mbps , IPv4 routing: 250 Mbps
- Capacity
- QoS hardware entries: 128000 , Security services entries: 128000 , Virtual interfaces (VLANs): 4096 , Multicast entries (IPv4): 70000 , Multicast entries (IPv6): 64000 , Multicast entries (shared between IPv4 and IPv6): 16000 , MAC addresses: 55000 , IPv6 routes: 128000 , IPv4 routes: 256000 , Spanning Tree Protocol instances: 3000 , Switched virtual interfaces (SVIs): 4096 , NetFlow entries: 128000
- Limited lifetime warranty
- Control processor
Processor / Memory / Storage
- Processors Installed
- 1.5 GHz
- RAM
- 2 GB (4 GB max) SDRAM
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Routing Protocol
- PIM-SM, PIM-DM, PIM-SSM
- Performance
- Capacity
- Uplink, IPv6 support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping
Communications
- Supported Flash Memory Cards
- SD Memory Card
- Expansion Slots
- 4 (total) / 4 (free) x SFP+
- 1 x management - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x USB - Type A
- Compatible Slots
- 1 x Expansion Slot
- NEBS level 3, CISPR 22 Class A, EN 61000-3-2, EN55022, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, CSA 22.2 No. 60950, EN 61000-6-1, AS/NZ 3548 Class B, AS/NZS 3260, ICES-003 Class A, FCC Part 15 A, EN 55022 Class A
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
