Product
Cisco Catalyst 4500 E-Series 48-Port
Quicklinx: 80LZWS00 Mfr#: WS-X4648-RJ45-E=
Cisco Catalyst 4500 Series Switches enable borderless networks, providing high-performance, mobile, and secure user experiences through Layer 2-4 switching. Enabling security, mobility, application performance, video, and energy savings over your network infrastructure, the Cisco Catalyst 4500 Switch supports resiliency, virtualization, and automation, further improving the ease of network use. Cisco Catalyst 4500 Series Switches provide borderless performance, scalability, and services with reduced total cost of ownership (TCO) and superior investment protection.
The Cisco Catalyst 4500 Switch delivers predictable and scalable high performance, with advanced dynamic quality of service (QoS) capabilities and configuration flexibility for deploying borderless networks. Integrated resiliency features in both hardware and software maximize network availability, helping to ensure workforce productivity, profitability, and customer success. Its centralized, innovative, and flexible system design helps ensure smooth migration to wire-speed IPv6 and 10 Gigabit Ethernet (GE). The forward and backward compatibility between generations of the Cisco Catalyst 4500 Series extends deployment life, providing exceptional investment protection, while reducing the (TCO).
The Cisco Catalyst 4500E Series is a high-performance, next-generation extension to the Cisco Catalyst 4500 Series. The E-Series is designed for a high-performance, mobile, and secure user experience with superior backward and forward compatibility, delivering exceptional investment protection for organizations of all sizes.
Cisco Catalyst 4500E Series Line Card - switch - 48 ports - plug-in module
Switch - 48 ports
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Flow control, half duplex mode, full duplex mode, Jumbo Frames support
IEEE 802.3x
36.2 cm x 27.3 cm x 3 cm
Cisco IOS 12.2(50)SG
Switch - 48 ports
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Compatible Slots
1 x Expansion Slot
Ports
48 x 10/100/1000
IEEE 802.3x
Status Indicators
Port status, link OK
48 x 1000Base-T RJ-45
NEBS level 3, ETSI, CISPR 22 Class A, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, CSA 22.2 No. 60950, AS/NZS 3548, FCC Part 15 A
36.2 cm
27.3 cm
3 cm
10 - 90% (non-condensing)
