Cisco CATALYST 4500 4200W AC DUAL CA
Quicklinx: 74L5WS00 Mfr#: PWR-C45-4200ACV
The dual input 4200 WAC power supply is designed to accept either 100V AC circuits or 200V AC circuits. Customer planning large scale PoE deployments can use the dual inputs in the 200V AC configuration. Customers planning for the future can deploy the 4200W power supply with a single 100V circuit.
Cisco 4200 WAC - power supply - 4200 Watt
Power supply
Input Voltage
AC 100/200 V
Output Voltage
3.3 / 12 V
Power Capacity
4200 Watt
Catalyst 4503, 4506, 4507R, 4510R
Power supply
Input Voltage
AC 100/200 V
Output Voltage
3.3 / 12 V
Power Capacity
4200 Watt
Integrated PoE
Cisco Catalyst 4503, 4506, 4507R, 4510R
