Product
Brand
Cisco Catalyst 3560X-48T-S 48-port Managed  Switch 48x 10/100/1000
Quicklinx: 8LM7WS00 Mfr#: WS-C3560X-48T-S
The Cisco Catalyst 3560-X switch is an enterprise-class standalone switch. This switch provides security, energy efficiency, and ease of operation with innovative features. The Cisco Catalyst 3560-X enhances productivity by enabling applications such as IP telephony, wireless, and video for borderless network experience.
Cisco Catalyst 3560X-48T-S - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Switching fabric bandwidth: 160 Gbps
Virtual interfaces (VLANs): 1005
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, HSRP, static IP routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
Hot swap module replacement, Layer 2 switching, dynamic IP address assignment, DHCP support, power over Ethernet (PoE), auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, Broadcast Storm Control, High Availability, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), PoE+, Per-VLAN Spanning Tree Plus (PVST+), Uni-Directional Link Detection (UDLD), Shaped Round Robin (SRR), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae
Power Redundancy
Optional
44.5 cm x 46 cm x 4.5 cm
7.3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Jumbo Frame Support
9216 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
128 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x RS-232 - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
186,778 hours
TUV GS, CISPR 22 Class A, GOST, cUL, NOM, VCCI Class A ITE, EN55022 Class A, CB, AS/NZS 60950-1, AS/NZ 3548 Class A, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 A, CSA C22.2 No. 60950-1
Software Included
Cisco IOS IP Base
44.5 cm
46 cm
4.5 cm
7.3 kg
Limited warranty - lifetime , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
8LM7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.14
8LM7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.25
8LM7 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.93
8LM7 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £43.89
