Cisco Catalyst 2960X-48TD-L Switch
Quicklinx: 95BGWS00 Mfr#: WS-C2960X-48TD-L
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£2,677.35 ex VAT
£3,212.82 inc VAT
Cisco Catalyst 2960-X series switch is fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations with intelligent services and a range of advanced Cisco IOS software features.
  • Scalable
    The Cisco Catalyst 2960-X series switch is scalable and resilient. With Cisco FlexStack-Plus stacking, which allows stacking of up to 8 switches and delivers 80 Gbps of stacking bandwidth, the Cisco Catalyst 2960-X enables ease of operation and management with a single configuration across the members of the stack. The Cisco Catalyst 2960-X series is resilient, with control plane redundancy across FlexStack-Plus switches. This minimizes traffic disruption if any stack member fails.
  • Smart
    The Cisco Catalyst 2960-X series enable intelligent access services, application visibility and control, and best-in-class energy management. Build for application visibility and control, these switches support NetFlow-Lite, which can be used to monitor, capture, and record traffic flows through the network. With industry-leading energy management capabilities such as Cisco EnergyWise to measure and control power usage, Energy Efficient Ethernet (EEE) and Switch and Downlink Hibernation modes to conserve power during periods of inactivity in the network, the Cisco Catalyst 2960-X with up to 80 percent energy savings is the greenest switch in the industry.
  • Simple
    Cisco Catalyst 2960-X series switch is simple to deploy, manages, and troubleshoots. As part of the Cisco Unified Access portfolio, the Cisco Catalyst 2960-X series switch is fully integrated with Cisco Prime to offer simple operation from a central location. It can also be managed by Cisco Network Assistant, which features an intuitive GUI where users can easily apply common services across Cisco switches and routers.
Cisco Catalyst 2960X-48TD-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 130.9 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Layer 2 switching, DHCP support, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IPv6 support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), Cisco EnergyWise technology, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Rapid Per-VLAN Spanning Tree Plus (PVRST+), IPv4 support, Shaped Round Robin (SRR), Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN), NetFlow, Hot Standby Router Protocol (HSRP) support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1ae, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 27.9 cm x 4.5 cm
4.3 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port transmission speed, port duplex mode, system, status, link/activity
48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 , 1 x console console - RJ-45 - RJ-45 , 1 x mini-USB console - mini-USB Type B - Type B management , 1 x USB Type A , 1 x 1000Base-TX 10Base-T/100Base-TX - RJ-45 - RJ-45 management , 2 x SFP+ - SFP+ uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Redundancy
Optional
Redundant Power System (RPS) connector
MTBF
445,460 hours
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, EN300-386, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN22, KN24, CNS 13438(95) Class A
Software Included
Cisco IOS LAN Base
44.5 cm
27.9 cm
4.5 cm
4.3 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95BG C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
95BG C2G 5m USB 2.0 A/B Cable - Black In Stock £5.24
95BG C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.51
95BG C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.71
95BG C2G USB Superbooster Extender Kit In Stock £39.76
Ports: 48
Managed: Yes
Brand: Cisco
Price Range Ex VAT: 1500+
