Cisco Catalyst 2960S-48TS-S - Switch - Managed - 48 x 10/100
Quicklinx: 7M0RWS00 Mfr#: WS-C2960S-48TS-S
Cisco introduces the new Cisco Catalyst 2960-S Series Switches, the leading Layer 2 edge switch series, providing improved ease of use, secure business operations, improved sustainability, and converged services for a borderless network experience. The Cisco Catalyst 2960-S Series of fixed-configuration access switches delivers functionality for entry-level enterprise, midmarket, and branch office networks.
  • Power over Ethernet Plus
    In addition to PoE 802.3af, the Cisco Catalyst 2960-S series switches support Power over Ethernet Plus (PoE+) (IEEE 802.3at standard), which provides up to 30W of power per port. The Cisco Catalyst 2960-S series switches can provide a lower total cost of ownership for deployments that incorporate Cisco IP phones, Cisco Aironet wireless LAN (WLAN) access points, or any IEEE 802.3af-compliant end device. PoE removes the need for wall power to each PoE-enabled device and eliminates the cost for additional electrical cabling and circuits that would otherwise be necessary in IP phone and WLAN deployments.
  • Sustainability
    Cisco Catalyst switching solutions enable greener practices through measurable power efficiency, integrated services, and continuous innovations such as Cisco EnergyWise, an enterprisewide solution that monitors and conserves energy with customized policies. Together, Cisco EnergyWise technology and Cisco Catalyst switches reduce greenhouse gas (GhG) emissions and increase energy cost savings and sustainable business behavior.
  • Cisco EnergyWise technology
    Cisco EnergyWise is an innovative architecture, added to fixed configuration switches, promoting companywide sustainability by reducing energy consumption across an entire corporate infrastructure and affecting more than 50 percent of global greenhouse gas emissions created by worldwide building infrastructure, a much greater effect than the 2 percent generated by the IT industry. Cisco EnergyWise enables companies to measure the power consumption of network infrastructure and network-attached devices and manage power consumption with specific policies, reducing power consumption to realize increased cost savings, potentially affecting any powered device.
  • Efficient switch operation
    Cisco Catalyst 2960-S series switches, designed and engineered by Cisco, provide optimum power saving, low power operations for industry best-in-class power management, and power consumption capabilities. The Cisco Catalyst 2960-S ports are capable of reduced power modes so that ports not in use can move into a lower power utilization state.
  • Intelligent power over ethernet management
    The Cisco Catalyst 2960-S PoE models support the latest PoE+ devices including Cisco IP phones and Cisco Aironet WLAN access points providing up to 30W of power per port, as well as any IEEE 802.3af-compliant end device.
  • CiscoWorks LAN Management Solution
    CiscoWorks LAN Management Solution (LMS) is a comprehensive network lifecycle management solution. It provides an extensive library of easy-to-use features to automate the initial and day-to-day management of your Cisco network infrastructure. CiscoWorks LMS uniquely uses Cisco hardware and software platform knowledge and operational experience into a powerful set of workflow-driven configuration, monitoring, troubleshooting, reporting, and administrative tools.
Cisco Catalyst 2960S-48TS-S - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 50 Gbps , Forwarding performance (64-byte packet size): 74.4 mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Layer 2 switching, auto-sensing per device, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 29.9 cm x 4.5 cm
4.77 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SFP (mini-GBIC) , 1 x console - mini-USB Type B management , 1 x console - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management , 1 x USB Type A
Internal power supply
53 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
357,740 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Lite
44.5 cm
29.9 cm
4.5 cm
4.77 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
7M0R Cisco 100FX SPF GE SFP Port for DSBU In Stock £168.33
7M0R Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £115.75
7M0R C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
7M0R Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £40.21
7M0R Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £81.57
7M0R Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £77.16
