The Cisco Catalyst 2960-S series switch is the leading layer 2 edge, providing improved ease of use, highly secure business operations, improved sustainability, and a borderless network experience. The Cisco Catalyst 2960-S series switch includes Cisco FlexStack switch stacking capability with 1 and 10 Gigabit connectivity. The Cisco Catalyst 2960-S series is fixed-configuration access switches designed for enterprise, midmarket, and branch office networks to provide lower total cost of ownership.
Sustainability
Cisco Catalyst switching solutions enable greener practices through measurable power efficiency, integrated services, and continuous innovations such as Cisco EnergyWise, an enterprisewide solution that monitors and conserves energy with customized policies. Together, Cisco EnergyWise technology and Cisco Catalyst switches reduce greenhouse gas (GhG) emissions and increase energy cost savings and sustainable business behavior. -
Cisco EnergyWise is an innovative architecture, added to fixed configuration switches, promoting companywide sustainability by reducing energy consumption across an entire corporate infrastructure and affecting more than 50 percent of global greenhouse gas emissions created by worldwide building infrastructure, a much greater effect than the 2 percent generated by the IT industry. Cisco EnergyWise enables companies to measure the power consumption of network infrastructure and network-attached devices and manage power consumption with specific policies, reducing power consumption to realize increased cost savings, potentially affecting any powered device. -
Efficient switch operation
Cisco Catalyst 2960-S series switches, designed and engineered by Cisco, provide optimum power saving, low power operations for industry best-in-class power management, and power consumption capabilities. The Cisco Catalyst 2960-S ports are capable of reduced power modes so that ports not in use can move into a lower power utilization state. -
Intelligent power over ethernet management
The Cisco Catalyst 2960-S PoE models support the latest PoE+ devices including Cisco IP phones and Cisco Aironet WLAN access points providing up to 30W of power per port, as well as any IEEE 802.3af-compliant end device. -
CiscoWorks LAN Management Solution
CiscoWorks LAN Management Solution (LMS) is a comprehensive network lifecycle management solution. It provides an extensive library of easy-to-use features to automate the initial and day-to-day management of your Cisco network infrastructure. CiscoWorks LMS uniquely uses Cisco hardware and software platform knowledge and operational experience into a powerful set of workflow-driven configuration, monitoring, troubleshooting, reporting, and administrative tools.
- Cisco Catalyst 2960S-48TS-L - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x SFP
- Performance
- Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 77.4 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
- Layer 2 switching, auto-sensing per device, dynamic IP address assignment, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Access Control List (ACL) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification, Remote Switch Port Analyzer (RSPAN)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 44.5 cm x 29.9 cm x 4.5 cm
- 4.77 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 8K entries
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 64 MB Flash
- Status Indicators
- Port status, port transmission speed, port duplex mode, power, system, link/activity
- 48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB Type A , 1 x console - mini-USB Type B management , 1 x console - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management , 4 x SFP (mini-GBIC)
- Expansion Slots
- 1 (total) / 1 (free) x Stacking Module
- Power Device
- Internal power supply
- Voltage Required
- 52 Watt
- Rack Mounting Kit
- Optional
- MTBF
- 328,058 hours
- TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, VCCI Class A ITE, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
- Software Included
- Cisco IOS LAN Base
- 44.5 cm
- 29.9 cm
- 4.5 cm
- 4.77 kg
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
- -5 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco 100FX SPF GE SFP Port for DSBU | In Stock | £168.33 |
Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £115.75 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £40.21 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £81.57 |
Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £77.16 |
