Your basket is empty
Cisco Catalyst 2960S-24TS-S 24 port Managed Rack-Mountable Switch
Quicklinx: 9JSJWS00 Mfr#: WS-C2960S-24TS-S
The Cisco Catalyst 2960S Series Switches are the leading layer 2 edge, providing improved ease of use, highly secure business operations, improved sustainability, and a borderless network experience.
Cisco Catalyst 2960S-24TS-S - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 50 Gbps , Forwarding performance (64-byte packet size): 38.7 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Layer 2 switching, auto-sensing per device, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), Port Security, MAC Address Notification
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
45 cm x 30 cm x 4.5 cm
4.5 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMP
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, port transmission speed, port duplex mode, power, system, link/activity
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SFP (mini-GBIC) , 1 x console - mini-USB Type B management , 1 x console - RJ-45 management , 1 x 10Base-T/100Base-TX - RJ-45 management , 1 x USB Type A
Internal power supply
36 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Optional
MTBF
335,014 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco IOS LAN Lite
45 cm
30 cm
4.5 cm
4.5 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply and fans - 5 years , New releases update
-5 °C
10 - 95% (non-condensing)
Humidity Range Storage
9JSJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
9JSJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
9JSJ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
9JSJ C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
