Midsize businesses protecting the Internet edge require the same level of protection as large, enterprise networks. You require enterprise-strength security, but purchasing a firewall that was built to handle the performance needs and budget of a large enterprise would be unnecessary and a waste of company resources. You need a firewall that provides the performance you need at a price you can afford, without compromising security.
Cisco ASA 5500 series adaptive security appliance fits your network and budget while offering the same proven level of security that protects some of the largest networks at some of the most security-conscious companies in the world. The ASA 5500 series scales to meet the performance and security requirements of a wide range of network applications, to correspond with your changing needs.
The Cisco ASA 5525-X is midrange security appliance that uses the Cisco SecureX framework for a context-aware approach to security that delivers multiple security services, multigigabit performance, flexible interface options, and redundant power supplies. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
- Cisco ASA 5525-X - security appliance - with FirePOWER Services
- Security appliance
- Form Factor
- Rack-mountable - 1U
- RAM
- 8 GB
- Flash Memory
- 8 GB
- Hard Drive
- 1
- Ports Qty
- 8
- Data Link Protocol
- Gigabit Ethernet
- Performance
- Firewall throughput: 2 Gbps , VPN throughput (3DES/AES): 300 Mbps , Connection rate: 20000 connections per second , Firewall + intrusion prevention throughput: 600 Mbps
- Capacity
- IPSec VPN peers: 750 , SSL VPN peers: 2 , Concurrent sessions: 500000 , Virtual interfaces (VLANs): 200 , Security contexts: 2
- Power
- AC 120/230 V (50/60 Hz)
- Pricing Type
- Refurbished
- 42.9 cm x 39.5 cm x 4.24 cm
- 6.77 kg
- 90 days warranty
- Bundled with
- FirePOWER Services
- Height (Rack Units)
- 1U
- 42.9 cm
- 39.5 cm
- 4.24 cm
- 6.77 kg
- Bundled with
Processor / Memory / Storage
- RAM
- 8 GB
- Flash Memory
- 8 GB
- Hard Drive
- SSD 1
- Form Factor
- Rack-mountable
- Ports Qty
- 8
- Connectivity Technology
- Wired
- Gigabit Ethernet
- IPSec
- Performance
- Capacity
- Status Indicators
- Power, Boot State, HDD activity, active, alarm, VPN
- Firewall protection, VPN support, VLAN support, High Availability
- Encryption Algorithm
- DES, Triple DES, AES
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 8 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
- C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, EN 60950-1, UL 60950-1 Second Edition, FCC Part 15 B Class A, VCCI V-3, KC, IEC 60950-1 Second Edition, CSA C22.2 No. 60950-1-07 Second Edition
- Pricing Type
- Refurbished
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 400 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - advance parts replacement - 90 days - response time: 10 days
- -5 °C
- 40 °C
