Cisco ASA 5515-X Security Appliance  6 Ports
Quicklinx: BRDPWS00 Mfr#: ASA5515-FPWR-K9
The Cisco ASA 5515-X midrange security appliance uses the Cisco SecureX framework for a context-aware, network-centric approach to security that enables consistent security enforcement throughout the organization. It is built on the same proven security platform as the rest of the ASA family of security appliances, and has been designed to deliver superior performance for exceptional operational efficiency.
With up to 1.2 Gbps of firewall throughput, 250000 concurrent firewall connections, 15000 connections per second, and 6 integrated 10/100/1000 Fast Ethernet interfaces, the ASA 5515-X is excellent choice for businesses requiring a high-performance, cost-effective, extensible security solution that can grow with their changing needs.
Cisco ASA 5515-X - security appliance - with FirePOWER Services
Security appliance
Rack-mountable - 1U
RAM
8 GB
Hard Drive
1
Ports Qty
6
Gigabit Ethernet
Performance
Firewall throughput: 1.2 Gbps , VPN throughput (3DES/AES): 250 Mbps , Connection rate: 15000 connections per second , Firewall + intrusion prevention throughput: 400 Mbps
IPSec VPN peers: 250 , SSL VPN peers: 2 , Concurrent sessions: 250000 , Virtual interfaces (VLANs): 100 , Security contexts: 2
42.9 cm x 39.5 cm x 4.2 cm
6.1 kg
90 days warranty
Bundled with
FirePOWER Services
Security appliance
Height (Rack Units)
1U
42.9 cm
39.5 cm
4.2 cm
6.1 kg
Bundled with
FirePOWER Services
Processor / Memory / Storage
RAM
8 GB
Hard Drive
SSD 1
Rack-mountable
Ports Qty
6
Wired
Gigabit Ethernet
Performance
Status Indicators
Power, HDD activity, active, alarm
Firewall protection, VPN support, VLAN support
Encryption Algorithm
DES, Triple DES
Expansion Slots
1 (total) / 1 (free) x expansion slot
6 x 1000Base-T - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x management - RJ-45 , 2 x USB 2.0 - Type A
VCCI, C-Tick, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1-07, ANSI C63.4-2009
Internal power supply
Installed Qty
1
Max Supported Qty
1
Software Included
Drivers & Utilities
Limited warranty - advance parts replacement - 90 days - response time: 10 days
-5 °C
10 - 90% (non-condensing)
BRDP C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
