Cisco ASA 5505 Sec Plus Appliance with Software
Quicklinx: 536DWS00 Mfr#: ASA5505SECBUNK9
Cisco ASA 5500 Series adaptive security appliances are purpose-built solutions that combine best-of-breed security and VPN services with the innovative Cisco Adaptive Identification and Mitigation (AIM) architecture. Designed as a core component of the Cisco Self-Defending Network, the Cisco ASA 5500 Series provides proactive threat defense that stops attacks before they spread through the network, controls network activity and application traffic, and delivers flexible VPN connectivity. The result is a powerful multifunction network security appliance family that provides the security breadth and depth for protecting home office, branch office, small and medium-sized business, and enterprise networks while reducing the overall deployment and operations costs and complexities associated with providing this new level of security.
Cisco ASA 5505 Firewall Edition Bundle - security appliance
Security appliance
Licence Qty
Unlimited-User Security Plus License
External
RAM
512 MB (installed) / 512 MB (max)
Flash Memory
128 MB
Ports Qty
8
Ethernet, Fast Ethernet
Performance
Firewall throughput: 150 Mbps , VPN throughput: 100 Mbps
IPSec VPN peers: 25 , SSL VPN peers: 2 , Concurrent sessions: 25000 , Virtual interfaces (VLANs): 20
Power Over Ethernet (PoE) Supported
PoE
20 cm x 17.4 cm x 4.4 cm
1.8 kg
Security appliance
Installed Modules Qty (Max)
0 (1)
20 cm
17.4 cm
4.4 cm
1.8 kg
Processor / Memory / Storage
RAM
512 MB (512 MB max) DDR SDRAM DIMM 184-PIN
Flash Memory
128 MB
External
Ports Qty
8
Wired
Network / Transport Protocol
IPSec
Performance
Firewall protection, DMZ port, power over Ethernet (PoE), VPN support, trunking, VLAN support, wall mountable
Encryption Algorithm
DES, Triple DES, AES, SSL
Expansion Slots
1 (total) / 1 (free) x expansion slot
6 x 100Base-TX - RJ-45 , 2 x 100Base-TX (PoE) - RJ-45 , 3 x USB 2.0 - Type A , 1 x management - RJ-45
Rack Mounting Kit
Optional
FCC Class B certified, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, FCC Part 15
PoE
External power adapter
5 - 95%
