Cisco ASA 5505 Sec Plus Appliance with Software
Quicklinx: 536DWS00 Mfr#: ASA5505SECBUNK9
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
Cisco ASA 5500 Series adaptive security appliances are purpose-built solutions that combine best-of-breed security and VPN services with the innovative Cisco Adaptive Identification and Mitigation (AIM) architecture. Designed as a core component of the Cisco Self-Defending Network, the Cisco ASA 5500 Series provides proactive threat defense that stops attacks before they spread through the network, controls network activity and application traffic, and delivers flexible VPN connectivity. The result is a powerful multifunction network security appliance family that provides the security breadth and depth for protecting home office, branch office, small and medium-sized business, and enterprise networks while reducing the overall deployment and operations costs and complexities associated with providing this new level of security.
Cisco ASA 5505 Firewall Edition Bundle - security appliance
Security appliance
Licence Qty
Unlimited-User Security Plus License
External
RAM
MB 512 (installed) / 512 MB (max)
Flash Memory
128 MB
Ports Qty
8
Ethernet, Fast Ethernet
Performance
Firewall throughput: 150 Mbps , VPN throughput: 100 Mbps
IPSec VPN peers: 25 , SSL VPN peers: 2 , Concurrent sessions: 25000 , Virtual interfaces (VLANs): 20
Power Over Ethernet (PoE) Supported
PoE
20 cm x 17.4 cm x 4.4 cm
1.8 kg
Security appliance
Installed Modules Qty (Max)
0 (1)
20 cm
17.4 cm
4.4 cm
1.8 kg
Processor / Memory / Storage
RAM
512 MB (512 MB max) DDR SDRAM DIMM 184-PIN
Flash Memory
128 MB
External
Ports Qty
8
Wired
Network / Transport Protocol
IPSec
Performance
Firewall protection, DMZ port, power over Ethernet (PoE), VPN support, trunking, VLAN support, wall mountable
Encryption Algorithm
DES, Triple DES, AES, SSL
Expansion Slots
1 (total) / 1 (free) x expansion slot
6 x 100Base-TX - RJ-45 , 2 x 100Base-TX (PoE) - RJ-45 , 3 x USB 2.0 - Type A , 1 x management - RJ-45
Rack Mounting Kit
Optional
FCC Class B certified, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, FCC Part 15
PoE
External power adapter
5 - 95%
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 536D 032911
Condition: Item has been opened and is in excellent condition.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £91.87
Ref: 536D 032912
Ref: 536D 032913
Ref: 536D 032914
Ref: 536D 032915
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £91.87
Ref: 536D 032916
Ref: 536D 038586
Condition: This item has been opened. It is in excellent condition.
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £91.87
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Cisco
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
